Old 07-04-2009, 06:10 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Tricked into buying charger!
I was at the track and found out that my current battery charger never charged my batteries fully. So someone that was there sold me a Mega 2 charger and said it would work with my Ni-mh battery packs. Then i looked in the manual and it said it was not made for those battery packs because it cant detect when they are fully charged. So can i still use it for them as long as i dont over charge them? I would tell if they are charged by how warm they are. Would that work or no?
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 07-04-2009, 06:15 PM   #2
If it says no then I would say no also.The difference between unplugging at the right temp & smoking the pack is the time it takes you to go to the other end of the house,piss & come back.Better safe than sorry.
butch man is offline   Reply With Quote
Old 07-04-2009, 06:20 PM   #3
jhipps835's Avatar
Wow this sucks. Now i have to buy a new charger. AWESOME
Old 07-04-2009, 06:30 PM   #4
jhipps835's Avatar
wait.... are there any Ni-CD hump receiver packs out there? To fit in a losi 8
Old 07-04-2009, 07:04 PM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
Any hump pack will fit in a 8 radio box. You have to use the hump cover and not the flat cover. Here is a page full of them any of the 5 cell packs will work except the last two. The configuration has to be 3 cells on bottom and 2 on top.
Click Here
Old 07-04-2009, 09:16 PM   #6
jhipps835's Avatar
No i meant Ni-cd hump packs not just any. Because thats what my charger only charges
Old 07-04-2009, 11:11 PM   #7
Frank L's Avatar
As long as it is in the 5+2 config it will fit in the 8ight box. Which charger are you using? The only difference from nicad to nimh is that the nimh needs a lower amp charge. If you charger can charge at 1.2 amps or lower then you can charge nimh packs on it.
Old 07-05-2009, 10:57 AM   #8
jhipps835's Avatar
I have a Mega 2 charger. But i think im just going to buy a new one for nimh cells.
Old 07-05-2009, 12:04 PM   #9
Give the guy back the charger and get your money back. Then buy what you need.
Chris Reilly is offline   Reply With Quote
Getting started:Tip's,Trick's,Newbie's come here! xsxracing Rookie Zone 59 01-03-2009 09:57 PM
TRITON CHARGER... buckeye34 Radio and Electronics 6 04-14-2008 10:29 AM
