Old 07-03-2009, 06:43 AM   #1
Default blowing glow plug
hi, guys. need help. have a go engine which has been very trust worthy. it seems today all of the sudden when i was trying to tune my engine, i started eating up go plugs.
the engine has been very good on 25% byrone.
temp was never above 200f
compression is still good. but not sure why
any input would be appreciated
muaythai is offline   Reply With Quote
Old 07-03-2009, 07:02 AM   #2
never above 200 ? its barely getting hot enough to run it without damaging the piston and sleeve. may be running too rich causing them to blow.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-03-2009, 07:07 AM   #3
2fst2c's Avatar
Trader Rating: 114 (100%+)
Might be a good idea to take it apart and make sure a glow plug element didn't do some damage or maybe some dirt got in it and is causing problems. I wouldn't keep trying to run it until you take it apart and atleast clean it all out good. Cheaper to look at it now then find out the cause later.
2fst2c is offline   Reply With Quote
Old 07-03-2009, 08:31 AM   #4
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
check your head clearance to...you may need to add a copper shim or 2
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 07-03-2009, 08:48 AM   #5
Davidka's Avatar
Trader Rating: 75 (100%+)
If the engine has some gallons on it and this just started then you should take off the backplate and check the lower rod bushing and rear bearing for play. The rear bearing could be going bad without necessarily becoming rough and the rod bushing wear symptoms are poor idle and short plug life without otherwise poor performance. Play in either results in inaccurate piston travel, that usually results in blown plugs.
Old 07-03-2009, 10:17 AM   #6
Default glow plug problem
cheers for the input guys. will have a look at my engine
Old 07-03-2009, 10:48 AM   #7
Default some very small grits
hi guys finally removed the top cooling head and back plate,
the conrod seems fine, pison is fine, just found some grits or fine metal bits on top of the piston head where the glow plug comes to contact.
will this be the cause of blowing my glow plug or is it bits of the glow plug?thanks
Old 07-03-2009, 10:53 AM   #8
houston's Avatar
Trader Rating: 91 (100%+)
you might wanna look at the bottom of your piston a little closer
it is more than likely broke in the wrist pin seat area
it sucks but replacement parts for taiwan engines are cheap
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 07-03-2009, 02:21 PM   #9
Default clearance
how would i know that?
Old 07-03-2009, 02:23 PM   #10
Default powerful team magic glow starter
guys , u head if your glow starter is to powerful , it can blow the plug
my team magic glow starter is real powerful. it literally lights up the plug. could this be the cause??
Old 07-03-2009, 02:35 PM   #11
Is it running overly rich and packing fuel into the plug? I had this problem on an engine with an air leak. Kept trying to richin it up to bring the temp down and in turn put way to much fuel into the engine. It would smash the electrode and the plug was toast.
marchesini80 is offline   Reply With Quote
Old 07-03-2009, 02:38 PM   #12
Trader Rating: 61 (100%+)
+1 too rich for a go motor im surprised its even moving ....i have never seen a go motor that ran good at 200 degrees ...i dont tune by temp ...but ive run many gotechs and they seem to run best in the 230-250 range ...inmho
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 07-03-2009, 02:53 PM   #13
Its supposed to light up the glow plug.
Old 07-03-2009, 06:11 PM   #14
wingracer's Avatar
Trader Rating: 23 (100%+)
Like someone else said, if it has been running fine and has a couple gallons or more on it, it is almost certainly a rod or bearing. Put a new rod and rear bearing in it and all your troubles are gone.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-03-2009, 06:42 PM   #15
Usually finicky tune then wont idle then blown plugs in that order are a sign of wear & Go motors while fast for the money are not the longest lasted motors.I would check for worn rod bushing then worn bearing,actually both at the same time but rods usually go first running that cold & depending on breakin.Motors that are very tight initially seem to be the ones that dont last that long. 4 screws & a simple check is all it takes to eliminate those.You sound like you have had no problems in however many gallons you have so far, so I am just assuming you have a basic grasp of tuning or at least how to tune to the feel you like(& if you can tune you should be able to find an air leak). Something that just happens out of the blue that you cant tune out seems that something changed other than tune,again assuming you know haw to.The only things that change are wear items Like rod & bearing,piston/sleeve wear wont cause blown plugs but poor bottom end & poor idle. Now with that said I'm not pointing out you cant follow 1-2-3 & arive at 4 because I have seen many experienced guys that should know better try & tune a worn rod & bearing all day before they give up,its just the human(male) condition not to get beat by a motor especialy in front of others. A lot of this is based on ussumptions but thats just what I've seen.
BTW the reason I suggest a rod like it aint no thang is the last I checked Go rods are like $18 & a TKO rear bearing is like $20-ish, not bad even if your not 100% sure their bad & cant find someone at the track that knows what bad feels like.
& call Russ at racefactor if he still owns it ,he was very helpfull to the go guys when he first started importing Go & may be more helpfull than anybody here.
butch man is offline   Reply With Quote
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4617 07-21-2017 11:28 PM
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Blowing glow plugs? rgrassey@me.com Nitro Off-Road 24 04-03-2009 05:48 AM
plug problems tinman13 Monster Trucks 7 05-10-2008 06:10 AM
Why? (Blowing plugs) Bob Moore Electric Off-Road 8 07-17-2006 12:19 PM
