Old 07-02-2009, 04:02 PM   #1
Default vspec or ninja???
I am getting a second engine for my mugen 6. I have a vspec and am thinking between a trinity extech, mugen ninja or another vspec. I love my vspec and the way it holds a tune. I read that the extech goes up to 44,000 rpm. And the ninja is a vspec and speed hybird that is very responsive with a very smooth power band.
Is there a big difference between the ninja and vspec? If there is not that much of a performance gain i will just get another vspec. I am not to crazy about the trinity motor even though i heard it kicks ass. If i get another vspec or a ninja i will already have the pipes for it and possibly spares and expierience tunning it.
So whats better ninja or vspec?
dreaux is offline   Reply With Quote
Old 07-02-2009, 04:10 PM   #2
gkn0315's Avatar
Trader Rating: 126 (100%+)
it all boils down to personal prefrence
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 07-02-2009, 04:23 PM   #3
Sounds to me like they are pretty much equal so i will probably just get another vspec. besides, it's really hard to find a ninja.
Old 07-02-2009, 04:24 PM   #4
It really is personal preference. But in my experience the VZB feels a little like an on/off switch and the Ninja is a little smoother. Personally I like the on/off switch. That is why I run a Speed II and a VZB.
Revooooooo is offline   Reply With Quote
Old 07-02-2009, 04:26 PM   #5
Really hard to find a Ninja? I went to google shopping and found 5 people selling a Ninja .21 in stock. Research before you post.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 07-02-2009, 04:32 PM   #6
smittyusmc's Avatar
If I was you I would go with the ninja I have a vspec and my friend has the ninja and that thing flat out halls both are great but the ninja seems to have a few less problems.
Hot Bodies Hara D8 - ODss .21
Team Associated B4.1 reedy 8.5, R10 Pro
Team Associated T4.1 OHP 17.5, Tekin RS
Team Associated B44.1 reedy 6.5, R10 Pro
smittyusmc is offline   Reply With Quote
Old 07-02-2009, 04:34 PM   #7
does anyone have any expierience with the vspec pro moddified? Is it worth the extra 100$$
Old 07-02-2009, 04:34 PM   #8
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
The ninja and v-spec are both awesome engines. Like already stated, the ninja has a smoother powerband but all the power of a v-spec. They both get about the same runtimes. The ninja WILL last longer because of the coated crank, speed con rod, and better case. You can't go wrong with either of them. Ninja isn't hard to find though. It's out of stock right now, but is there.
http://carolinasrc.com/Webstore/Scri...dproduct=11957
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-02-2009, 04:38 PM   #9
I would suggest doing some research. There are plenty of threads on all of these engines.
The pro mod is a cross between a v-spec and a speed. It has a speed crank, rod and bearings. Standard v-spec piston, sleeve, backplate, etc.. And a new drilled blue head. It should preform almost identical to a speed. But if I were you I would just go the whole way and get the speed. They can be found for around the price of the pro mod.
-Koby Kubrin-
Old 07-02-2009, 04:40 PM   #10
thanx jammin. I did see a new speed on ebay for 399$
Old 07-02-2009, 04:44 PM   #11
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I would use the Ninja over a VSpec. The Ninja seems to handle topend power better than a VSpec and should last longer.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-02-2009, 04:57 PM   #12
That must be the aluminum head speed with the 21J carb. I would look for the speed worlds as it doesn't have the 21J carb.
Old 07-02-2009, 05:01 PM   #13
Uh, yeah it does. It has the same carb that the AL heads have had for over a year now. It's called the 21JS because it has the speed insert set. The worlds and AL are internally the same. Only differences are the drilled head, smaller insert set, and some engraving.
The 21J carbs are the best carbs OS has. They are on all current v-specs, speeds, ninjas and 28xz's.
-Koby Kubrin-
Old 07-02-2009, 05:01 PM   #14
the speed has a hole in the con rod for oil passage and it has parralell rings on the piston to trap oil from the fuel to add compression + the chrome plated piston + coated and filled crank + ceramic bearing + a cooling head with 18 holes + better inserts and better crankcase design. It really sounds woth the 500$ Plus it looks absolutley killer! I might have to wait and hold out a week or two and get this puppy!!
Old 07-02-2009, 05:05 PM   #15
Almost every engine including the normal v-spec has the oil rings in the piston. The WC is the one with the drilled head. Like I said in my above post the normal AL speed and WC are almost the same. That speed you saw on ebay is basically the WC engine. Just so you know that you can spend $400 and have the same engine.
-Koby Kubrin-
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
OS V-Spec II World Edition or Mugen Ninja JX21??? In3g_z33 Nitro Off-Road 64 08-09-2009 08:17 PM
Engine for Truggy? What's best? Victory Side Nitro Off-Road 28 07-15-2009 04:51 PM
v spec or v spec worlds randy racer Nitro Off-Road 27 05-18-2009 07:06 AM
standard Vspec or Ninja JX B01A? gameholic2 Nitro Off-Road 19 03-26-2009 02:43 PM
iRacingWerkz Nitro Fest II @ Turf City(GP Offroad race registration, 20th May 2007) iRacingWerkz Singapore R/C Racers 122 05-28-2007 02:36 AM
