Old 07-02-2009, 10:37 AM   #1
Send a message via MSN to KROGOTH
Default Break-In Worries
Ok. I just got my new O.S. .21TM, and after spending yesterday prepping it I started break in today. Finished tank 1 recently. I planned on heat cycling it originally, but I was apparently running it ridiculously rich for that first tank and it was hard to get the temp above 150 degrees. Im thinking the high speed needle needs leaned out, but Im really nervous about this.
Im trying to break this engine right and take better care of it than I did my 3.3.
Anyone have any advice on how I should proceed?
Traxxas Slayer
(can i haz races nao?)
HPI Baja 5B
(~current pride and joy~)
Traxxas Bandit (in pieces and abandoned)
KROGOTH is offline   Reply With Quote
Old 07-02-2009, 10:47 AM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Follow the break in procedures to the tee that are posted in the sticky at the top of the page. Wrap the cooling head so heat does not escape, and get yourself a heat gun..Monitor temps often and keep it at the proper temp with the gun. You can go leaner also, but just make sure its still rich
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-03-2009, 05:29 AM   #3
Ok heres the problem Im having. I started heat cycling it today. Waiting on it to cool right now. But even with a sock wrapped around the cooling head, its hard to get the temp to above 150. Im going to assume its cause its running very rich, but I dont think it should be leaned out while its being broke in, should it?
Traxxas Slayer
HPI Baja 5B
Old 07-03-2009, 07:22 AM   #4
OK nevermind, think I got it down. i leaned it out a tad more, and its still pretty much dumping fuel out the back of the engine but I can get the temp up in the 200 degree area and keep it there. It seems weak as hell, but Im attributing that to the richness that its being run at. Gonna run it like this for a few more tanks I think, and then she should be good to go.
Traxxas Slayer
HPI Baja 5B
Old 07-03-2009, 07:24 AM   #5
running it too rich and not up to temp can do more harm. you have a ways to go before you can consider it being too lean. read the break in bible and if it takes leaning it some to get the temps where they need to be then do it.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-03-2009, 08:19 AM   #6
tonydig11's Avatar
Trader Rating: 21 (100%+)
i had the same engine in my tmax. I had to lean it a half a turn just to get temp up. depending on weather the stock settings are just a ball park.
tonydig11 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Tamiya TB-Evolution III rc-zombies Electric On-Road 7237 11-16-2016 05:09 AM
All abt kyosho ZX5 post here SuperEk4 Singapore R/C Racers 775 01-04-2010 09:36 PM
Nitro TC3 thamjk Malaysian R/C Racers 5356 01-04-2009 07:18 PM
MBX6 stability racer_hh Nitro Off-Road 15 10-28-2008 06:00 PM
Racing 4x4s Motoxpro Electric Off-Road 13 06-19-2007 01:54 AM
HK Talk Version 1.1 fai Hong Kong Racing 18317 05-13-2007 07:22 PM
