Old 06-30-2009, 06:21 PM   #1
pl_unc86's Avatar
Trader Rating: 16 (100%+)
Default Mbx6 Diff question
Anyway to stop the notches that are formed on the diff cup from the pinion? I assume this is from the chassis flex?
pl_unc86 is offline   Reply With Quote
Old 06-30-2009, 06:25 PM   #2
Davidka's Avatar
Trader Rating: 75 (100%+)
It's likely that your pinion bearings aren't fully seated in the gear cases or the universal collar is not all the way down on the pinion's shaft allowing the pinion to walk in and out of the gear case slightly. If the pinion and universals are assembled correctly it should be impossible for the pinion to contact the diff cups.
Old 06-30-2009, 06:28 PM   #3
pl_unc86's Avatar
Thanks for the tip, i will check that out
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
