Old 06-30-2009, 12:41 PM   #1
Send a message via MSN to BlackSS
Default Receiver Battery Pack Questions
I have a Venom 1200mah (older, needs to have a wire fixed) and Duratrax 1600mah (just bought today) hump pack nimh. I have a Duratrax Piranha digital peak charger and am wondering how I should be charging them. I've been out of the hobby for a while.
I have been charging the Venom 1200mah @ 1 amp, 8mV/C
Is this correct? I don't really know what the 8mV/C means or how it effects the charge. I'd like to have a normal charge when I have time and a quick charge when I'm bashing.
BlackSS is offline   Reply With Quote
Old 06-30-2009, 12:45 PM   #2
Trader Rating: 27 (100%+)
1 amp is fine...i wouldnt charge ut any higher then that...
Alex B
Kyosho America/Byron Fuels/J concepts
For all your painting needs!
Elite Paint Workz
ElitePaintWorkz@gmail.com
mist467 is offline   Reply With Quote
Old 06-30-2009, 12:58 PM   #3
What about the peak rate? Duratrax recommends 8mV/C for NiMh batteries.
Old 06-30-2009, 03:09 PM   #4
5mv
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 06-30-2009, 03:20 PM   #5
Thanks, what difference does it make? Just wondering...
Old 06-30-2009, 06:41 PM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by roadracer43 View Post
5mv
+1 on 1 amp and 5mv. At 8mv you would overcharge the pack. I charge my packs at .9 amp charge and discharge cycle and 1.2 charge only at the track to top them off.
Old 06-30-2009, 08:18 PM   #7
The detection V is exactly that.When those batts peak they have a large fast change in voltage. The mV you set is how much change the charger looks for to determine the pack is peaked. The higher the # the more the charger will charge before it shuts off.When packs are new they are more reliable/precice in that characteritic & the charger will be able to propperly peak them a t a lower mV setting. The older & more dissimiler the cells get the harder it is for the charger to sence their true paek & you have to raise the mV# up to get the pack to not false peak. If you have to go above .8mV per cell toss the pack & get a new one. If one cell of the 5 is really bad it wont have the same V change as the others & its a per cell # your setting on the dial only the charger actualy looks at it as a combined V & like I said that 1 cell not responding propperly will cause the charger to over charge the others looking for that Voltage change & that will cause 1 or more cells to vent & if your in a hurry for your next race you may notice untill you put your car down on the track & pull trigger.So after all that just know lower# is better if your batt is good.
butch man is offline   Reply With Quote
Xray NT1 aantonis Nitro On-Road 7512 08-14-2017 02:55 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
:( going LIPO.... Allumina Radio and Electronics 10 12-19-2008 10:59 PM
2008 AARCMCC 1/10th scale EP off road National titles dragon26 Australian Racing 635 05-01-2008 08:34 PM
RC Clean up sale garage sale Rotary Racer R/C Items: For Sale/Trade 12 06-19-2007 07:08 AM
Lots of R/C goodies for sale, just in time for christmas!!! SavageSS27 R/C Items: For Sale/Trade 37 01-26-2006 05:24 PM
Need help with micro setup microdude Electric On-Road 12 02-29-2004 07:25 PM
