Old 06-30-2009, 08:55 AM   #1
rcgeezer's Avatar
Default Kyosho Universal Question
I need to replace the pin that holds the front/rear universals together and is locked in by the set screw. Does anyone know the size of that pin, or better yet a part number for A-main hobbies would be greatly appreciated! Thanks for the help!!
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 06-30-2009, 09:06 AM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
I can see why you want just the pin those suckers are expensive. Amain does not seem to have any type of pin set. I know the losi part not that helps you. Take your caliper and measure the length and diameter in mm and I can check if there is anything close in the losi pin set. That's the same problem I had when I had a str parts were a mystery and fndng them even worse. I have a buddy that drives a strr I can give him a call and see if he knows if you want.
Old 06-30-2009, 10:02 AM   #3
rcgeezer's Avatar
That would be great, thanks Frank!
Old 06-30-2009, 01:37 PM   #4
Frank L's Avatar
Rcgeezer I talked to my buddy. He used to own a hobby store in Hayward and he still gets his parts from the distributor. He told me there is no way to rebuild that universal you have to replace it. That sucks. So if anyone else knows I will be suprised. Anyway measure the pin and I'll see if I have something close.
Old 06-30-2009, 02:05 PM   #5
shesha's Avatar
Send a message via MSN to shesha
Maybe consider to replace with fioroni and then have the pins replaced if they wear out...
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 11:50 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 07:36 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
CEN Matrix TR t4usee Nitro Off-Road 1798 03-29-2010 09:57 AM
