Old 06-29-2009, 09:18 PM   #1
Default Most fuel economical .21 you have ever had?
Hello
I am going to be competing in an enduro event with my buggy or truggy (3hrs), I am going to be taking part in it with a .21 race motor and was wondering which is the most fuel economical as my local track is very dusty and I currently have an OS .21 speed and am just making 10mins in my truggy with a 6.5mm restrictor and throttle travel set to 75% of the 6.5mm restrictor...
If you guys could list some extremely fuel economical motors I would really appreciate it...
Thankyou
RUF-VK is offline   Reply With Quote
Old 06-29-2009, 09:29 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by RUF-VK View Post
Hello
Thankyou
novarossi n21b limited
6mm restrictor and you will get lots o runtime .
use a fioroni turbo sliding clutch for the enduro race
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-29-2009, 09:43 PM   #3
So you are saying that the Novarossi N21B ($180) gets better run time than my OS speed
Old 06-29-2009, 09:47 PM   #4
houston's Avatar
i sell them for 155$ and do custom engines also ie. ceramic bearings , mods , etc.
and yes
Old 06-29-2009, 09:48 PM   #5
thenova70ss's Avatar
Trader Rating: 52 (100%+)
Yep i had one and would get 11min run time with an 086 pipe.
CHRIS CREWS
Pro Speed Racing Optima MX1 Buggy http://www.global-hobbies.com.my
Cold Fusion R/C Products Team Driver - www.coldfusionrcproducts.com
Rc Pro ProDucts Team Driver www.rcproproducts.com
Hobby Pro USA Team Driver www.vp-pro-usa.com
thenova70ss is offline   Reply With Quote
Old 06-29-2009, 10:03 PM   #6
sickboy's Avatar
Trader Rating: 72 (100%+)
all day long..........
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 06-29-2009, 10:04 PM   #7
I was thinking more along the lines of an:
RB WS7III (heard they get 14mins)
Novarossi plus 4
Go Tech .21 5 port
Sirio EVO 4 Kanai
Heard they are the most fuel economical. I want to buy an engine that will be the most fuel economical and not buy one and make a mistake and try selling it.
Old 06-29-2009, 10:06 PM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
I have an os speed in my 2.0 truggy and I get 10.5 to 11 on a large track with a 6.5mm restrictor and an eb mods head button. The button makes it so you are on the throttle much less because it moves the powerband and increases both low and high. Best combo ever. I also run a mugen 2042 and mugen L shaped header. This combo rocks.
The powerhousercperfoemance.com modded .21 with a 7mm restrictor A 053 pipe and long header will get about the same runtime. Both engines are great. I highly reccomed both.
Old 06-29-2009, 10:27 PM   #9
AZrcdriver's Avatar
Stock 21B Limited still running rich and made a 12 min main on 1 tank in my truggy at the Nitro Pit which is a 125x200 track area and power to burn.
Never heard that from an OS that I know of.
Houston knows motors, listen to what he has to say.
HobbyTown USA - Scottsdale RC Speedway
Supporter of: KBRL and local tracks
AZrcdriver is offline   Reply With Quote
Old 06-29-2009, 10:44 PM   #10
Since I am going to be running it for 3 hours it will be a little on the richer side as oposed to running a full on race tune, that is why I want a motor that can hold 10 mins per tank + running a little rich
Old 06-29-2009, 11:02 PM   #11
AZrcdriver's Avatar
Mine would run under 220 all the time, it hit 240 on me once after a race but that was the highest it had ever been.
Got my carb out of wack letting other people touch it so I sent it to Fusion to get squared away. Just got it back but I need to get it put back in to run but I'm just trying to decide put it in the buggy where it is supposed to go or the truggy since it is what I am running mostly right now.
I want the run times back over my 28 at around 6.5 to 7 minutes.
Old 06-30-2009, 12:13 AM   #12
Honestly, it is not really the run time that you should be worried about. The longevity of the motor and the clutch are the biggest things. We did an endurance like yours in CO and these were the biggest problems. Some of the motors (I won't mention brands) didn't hold up and only a few did. Any race motor should take the abuse with the proper tune. Just make sure everything else holds up. Its nitro...things break.
Revooooooo is offline   Reply With Quote
Old 06-30-2009, 03:17 AM   #13
TTR:EB4's Avatar
ive got a standard v-spec in my buggy.. and that gets around 13 - 14minutes a tank.
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 06-30-2009, 03:55 AM   #14
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Hello
Thankyou
I get about 12 minutes out of a VSPEC with ceramic bearings installed, running a Dynamite 053 pipe... and it isn't even really broke in yet (maybe half a gallon through it.) It depends on the track though.
I personally don't think the speed is a good truggy engine... not enough bottom end.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-30-2009, 04:46 AM   #15
Try this, surprisingly good!
http://www.rcmart.com/catalog/rc-eng...t-p-25076.html
I paired it with an OFNA 053. Nice smooth managable power and very good fuel economy. Plus you won't feel sorry for it when running on the track, which is the key point
cheapskate.brok is offline   Reply With Quote
