Old 06-29-2009, 04:28 PM   #1
helivaguy's Avatar
Trader Rating: 42 (100%+)
Default novarossi/go-tech rod question
will the go-tech rod fit the novarossi plus 21-5?
if so which??
thanks
helivaguy is offline   Reply With Quote
Old 06-29-2009, 04:35 PM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Yes they will fit. They aren't of the same quality obviously, but they will fit.
http://carolinasrc.com/Webstore/Scri...idproduct=3935
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-29-2009, 04:48 PM   #3
helivaguy's Avatar
thankyou sir,
also i found the axe rossi rod will fit.
Old 06-29-2009, 04:57 PM   #4
Yes they do. But the finishing on the Axe is the worst. The Axe and Go Tech rods are much more chunky and they don't spool up as fast compared to Nova's own conrods. The Nova's are much much more lighter too...
cheapskate.brok is offline   Reply With Quote
Old 06-29-2009, 05:05 PM   #5
helivaguy's Avatar
you are certainly correct,
but if i get another gallon out of it i will be happy
Old 06-29-2009, 06:39 PM   #6
Trader Rating: 7 (89%+)
yup it will fit done it before. But it will never be thesame engine but it will still get you around the tracks with no problem. Me I did not feel the difference cause I am slow. But for others who knows the engine says it lost some of the punch. I was argueing could not be caused by the rod maybe the bearing or something.
I even used the whole PSR of Go seven port for my nova 7 bt. Engine still runs but eats plugs a lot. They are saying that the go techs piston is flat while the original 7bt is a little convex. Extra shimming did the trick.
oggietiu is offline   Reply With Quote
Novarossi engines thread EVOLUTION Onroad Nitro Engine Zone 5360 08-14-2017 11:48 PM
Sirio cl3b 3 port engine and pipe set...good for a budget set-up? hugh_b Nitro Off-Road 31 01-01-2009 06:09 AM
A quick Novarossi Plus21 question air8 Nitro Off-Road 44 08-30-2008 02:18 AM
Bore vs Stroke vs Displacement rmdhawaii Onroad Nitro Engine Zone 163 11-07-2006 12:07 PM
Manufacturer Illusion s8in Nitro On-Road 9 10-24-2005 10:44 AM
Using 5 port piston sleeve on MT12/XT12 (long con rod variants) ok? Hammer0412 Nitro On-Road 13 08-20-2002 07:38 PM
