Old 06-29-2009, 11:45 PM   #16
Evetually gonna need a iron in this hobby,esp when you run a basher. Just think how much money he'll save soldering broken arms back together
butch man is offline   Reply With Quote
Old 06-30-2009, 03:40 AM   #17
Send a message via MSN to helgso
When heating up the nail, could I use a normal lighter?
helgso is offline   Reply With Quote
Old 06-30-2009, 03:47 AM   #18
domekat's Avatar
Use these they are great when the Hex is rounded
Fujiya 175mm Screw Removing Pliers
Available at Jaycar.com
domekat is offline   Reply With Quote
Old 06-30-2009, 03:57 AM   #19
You know, that really looks like a good tool. But that grip it has, which goes around the rounded screw seems to me like it is just going to strip the screw.
Old 06-30-2009, 07:00 AM   #20
Frank L's Avatar
Trader Rating: 148 (100%+)
Heat it up that's the oily way to break the loctite. If you strip out the head use a dremel and cut a slot on the screw it will come ou that way. If there is plasic in your engine mount then you need a new alum one piece mount. Check out kingheadz. A one piece mount will not only help prevent flex around the clutch bell and spur gear, it adds strength to the case and makes pulling the engine out and putting it back in very easy. Spend he 50 bucks it makes life easier.
Old 06-30-2009, 09:16 AM   #21
Jaz240's Avatar
Trader Rating: 52 (100%+)
Yes
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-30-2009, 10:05 AM   #22
heat them up, if they strip you can easily use pliers to get them screws off. Easy fix.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-01-2009, 10:43 AM   #23
I have two McCoy59 glow plugs which I have kept since 2005, brand new. Am I safe to use them with my engine, or are they too old?
Old 07-01-2009, 10:52 AM   #24
Jaz240's Avatar
Glow plugs dont go bad, as long as they are sealed, not full of dirt
Old 07-01-2009, 10:57 AM   #25
Good, thanks for the quick reply. I'm about to heat up my nail to losen the engine mounts screws. But before that, I came across a toolbox available for me to purchase. Some quality Hex-Screwdrivers. I looked in my manual and the sizes in that toolbox fit my needs.
Do you recommend buying this set (hex screwdrivers) and losen the screws with those instead of the low-quality hex drivers that were included with my kit? (The drivers that are like "L" in shape)
Old 07-01-2009, 11:23 AM   #26
Jaz240's Avatar
A good set of tools is a must have if you are serious about the hobby
Kyosho V-ONE RRR Evo boy2rc Nitro On-Road 3234 08-06-2014 11:43 PM
AREA52 RC RANCH RACEWAY Leopard1 Northwest Racers 5272 01-01-2011 01:09 PM
Need HELP with V-Spec Mo-Bo0st Nitro Off-Road 9 07-12-2008 08:47 AM
Engine upgrade help please?..? RS4 3 EVO DriveToLive Onroad Nitro Engine Zone 16 12-17-2005 01:47 PM
