Old 06-28-2009, 05:58 PM   #1
Questions?? Odonnell ss .21 help
I just got one, and broke it in. It's fast and stays running but has trouble coming back down to a steady idle. I've tried all my usual tricks but no success. Anyone got some after break in needle settings for me? Thanks.
alec rogain is offline   Reply With Quote
Old 06-28-2009, 06:35 PM   #2
Trader Rating: 14 (100%+)
im having the same issue with mine, i think im still fat on bottom, ill check needles and get back to you
jlo
jlo8864 is offline   Reply With Quote
Old 06-28-2009, 06:47 PM   #3
this is where i ran mime today 90 deg. 50% hum. 2 turns out on top about 3/4 turn out on bottom, that sounds funny for the bottom, but thats where i had it and it still seemed a little fat, i need help too.
jlo
Old 06-28-2009, 06:58 PM   #4
Send a message via Yahoo to windellmc
We had to turn the idle speed screw out about two turns on my engine before we even started to tune on mine. Otherwise it would high idle after running down the straight.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 06-28-2009, 07:22 PM   #5
JPierson's Avatar
Ran mine today at 230 and got 11 mine per tank you just have to lower you idle and fattin up the low speed needle! Take your time tuneing make shure you run a lap after every adjustment! This mill is great you will love it!!
HB D8 & D8t GRP .21 & O'DONNELL SS.21
JR 8711 & 9100s & Hitec 7955TG
M11 2.4 FHSS-2 •TEAM*TERRIBLES•
"I know I can't drive!! You still ACT like you can!!"
JPierson is offline   Reply With Quote
Old 06-28-2009, 08:53 PM   #6
v6shooter's Avatar
How much fuel do u have in It so far JPierson
v6shooter is offline   Reply With Quote
Old 06-29-2009, 12:50 AM   #7
Marcus Falconie's Avatar
Did you get 11min with a JP3?
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 06-29-2009, 05:06 AM   #8
COBRARACING's Avatar
3.5 turns out on bottom and top ,get it to temp and then work your way in by throttle and tune especially for bottom end .if it bogs go in 1/8th of a turn each time until its not flat on top and bottom .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-29-2009, 07:19 AM   #9
JPierson's Avatar
Smile
little over a gal. Through it, O.S.pipe not jp3. Jp3 is for
my GRP.
Old 06-29-2009, 11:33 AM   #10
its great to see everyone on here with the new engine.
from what i gather on all the different forums so far (and this is just observation) is that the OS 2050 and The AE2035 pipes have shown to provide the best power/mileage results. also optimum temps looks like it is between 230 - 240 degrees.
like many of you I had to turn the idle down a bunch before tuning. once i did that tunning it was super easy. This motor seems to have a really big "window" so you dont have to be a master tuner by any means to get the most out of this motor
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 06-29-2009, 11:38 AM   #11
If it doesen't settle down even if the LSN is way rich, this is what to do:
Lean bottom and lean Idle, lean them both a lot, but naturally since LSN is way rich, this needs to be leaned quite much.
Shit you not!
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 06-29-2009, 12:32 PM   #12
cobraracing - 3.5 on bottom and top, mine won't even start that fat, i have be told some od guys running 1 turn out on bottom and 2 turns out on top, this motor my be suited for buggy better than truggy.
jlo
