Old 06-28-2009, 10:56 AM   #1
vti-chris's Avatar
Default Do you use a switch or connector
Do you use an On/OFF switch for receiver/battery connection?
If switch...which is the best and how often do you change it?
If connector which one do you use?
Which setup has cost you the "most runaways"?
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 06-28-2009, 11:00 AM   #2
MrUnlimited's Avatar
I do use a switch between the battery and the receiver. Most of the receivers and batteries are boxed in a buggy. The are special dust covers available for switches if that is the problem.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 06-28-2009, 11:04 AM   #3
cary's Avatar
Trader Rating: 67 (100%+)
I just got rid of the switch I used a small servo lead form the rx
and use the plugs that where on them just one less thing to go
wrong I'm liking it so far
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 06-28-2009, 11:11 AM   #4
vti-chris's Avatar
That's what i use as well(the plugs from the battery and Y harness) but wanted to know if it will eventually fail since the usage is too much, plug...unplug..., plug...unplug..., plug...unplug..., plug...unplug..., plug...unplug...
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 06-28-2009, 11:16 AM   #5
I use a switch,Futaba long knob & change it every 6 months or so. No problems in the 2 yrs I been using that switch but I had other other switch brands before the Futaba that were involved when I had electrical problems but I always carried spares for those too though it was seldom the switches problem causing them.
Switches can cause problems but so can worn connectors,those spot welded battery bars on reciever packs,recievers bouncing around,servos thet hit the chassis when you land wrong & wires that chafe on when pulled tight around something & next to a nitro motor vibrating at 40,000 rpm. My last elec problem was reciever batt wires chafing between the reciever batt & reciever box wall till there was only 3 strands left in each wire. Ive had more servo & wire problems than switch problems.
BTW the batt wire problem was in the same car you run,you might want to check how your wires leave the pack & blow dirt out of the box often since I know you dont take the batt door off except under penalty of deth.
butch man is offline   Reply With Quote
Old 06-28-2009, 11:20 AM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
+1 on the switchless. I use a mini deans plug. It will never fail and there is no question as to weather its on or off. I have seen many racers struggle with faulty switches, but never a faulty connector. Go switchless its the way to go.
Old 06-28-2009, 11:37 AM   #7
1+ So very true.One good runaway and you'll understand.
The Working Man is offline   Reply With Quote
Old 06-28-2009, 11:39 AM   #8
Jaz240's Avatar
Trader Rating: 52 (100%+)
+2, I have had 2-3 various problems with switches, so now its Mini-deans direct plug in for me also
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-28-2009, 11:48 AM   #9
I have a JR switch with charging connector that I bought a month ago. Before I had a JR switch that came with my XXX-NT RTR that had oil and fuel all over it so I didn't expect to last long. But switch's are so much easier. I have my charging connector where I do't even have to take off the body to recharge my receiver battery in between races. I have used regular Deans before, but they were harder to get on and off than the standard black ones I use now and they definitly weren't needed.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-29-2009, 05:38 AM   #10
I have a KO-Propo electronic switch I used to run it on my 1/5th onroad car and have been thinking about putting it onto my Truggy. Which I think I will do because i am sick of the rubber protectors tearing on the switches.
I can not find anywhere to buy another KO switch they are so good you press a tiny little sealed button to turn it on or off. Only draw back is most don't know how it works as you need to hold the button down for about 300mSec to change the state from on to off and vise versa. Also draws current in off mode but is minimal 5mAh. Again it is the best switch I have used.
Cheers,
Rolf
www.kellettshobbies.com
one5racing is there any other kind!
hassro is offline   Reply With Quote
Old 06-29-2009, 06:21 AM   #11
the tracks here, you must have a switch - never had a problem with one
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-29-2009, 06:32 AM   #12
I am using Mini Deans as well, it's great. I have it coming out of the radio box so I can plug it in and unplug it without opening the box.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 06-29-2009, 07:58 AM   #13
Jaz240's Avatar
Explain what that means..by the "tracks here" whats different about your tracks that a switch is "required"
Old 06-29-2009, 08:34 AM   #14
He means that a switch must be on your car to be allowed to race.
PILL is offline   Reply With Quote
Old 06-29-2009, 08:37 AM   #15
Frank L's Avatar
Why would a switch be required to race? It does not prevent a run away the car still runs. I don't see what purpose requiring a switch does.
1/12 forum ovalnator Electric On-Road 45709 Today 05:19 AM
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 06:15 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
"cooked batteries" h4nsm0l3m4n Electric On-Road 15 03-18-2007 10:48 AM
when not using a switch how do run your battery wire setup ? mrgsr Nitro On-Road 9 04-25-2006 09:49 AM
