Old 06-26-2009, 09:20 AM   #1
t0adman's Avatar
Post Ideal charging settings for NiMH Rx packs
Hey guys - sorry if this isn't the exact right forum section to post this but I'm raicng tomorrow and charging now. This section, as we all know, gets 10x the looks the radio section does.
So I'm using the Duratrax Onyx 230 to charge my NiMH Rx packs. I have the OFNA 1700, the Stickman 2500 and the Reedy 1600.
Right now I've got it set at a .3A charge, 6.0V rate nominal voltage (per the battery), and peak sens. setting at 3mV/C, no timeout, 0mA trickle.
Right now I've got plenty of time to charge and I'm trying to maximize battery charge, output time and battery life. Would you guys recommend different settings? If so, what?
Racing tomorrow! TIA.
RC8e, SCRT10e, Mod Slash 2WD
[Team Terribles]
t0adman is offline   Reply With Quote
Old 06-26-2009, 09:22 AM   #2
beginner4life's Avatar
Trader Rating: 9 (91%+)
that should work just fine. except i would recommend buming it up to like .4 because it weill take reallly long otherwise.
*Team Terribles*
RC8T-RB S3-Hitec Servos- Spektrum
beginner4life is offline   Reply With Quote
Old 06-26-2009, 09:24 AM   #3
t0adman's Avatar
I was under the impression the lower the charge amp the longer the battery life and better it is for the battery. Is there a certain level under which that's not necessary? Is that .5A?
[Team Terribles]
Old 06-26-2009, 10:16 AM   #4
unsp0ken's Avatar
Trader Rating: 24 (100%+)
i charge mine at .3 also. slow charge is best; less chance of getting false peaks. only charge fast if you're on a time crunch.
unsp0ken is offline   Reply With Quote
Old 06-26-2009, 10:41 AM   #5
cary's Avatar
Trader Rating: 67 (100%+)
I have had good luck at .5A charge rate on 1600 reedy packs
just switch over to lipo last two races and I'm lovin it 2000
pack had more than enough for all day
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 06-26-2009, 10:44 AM   #6
When I am charging my EP1500 the night before of the day of, I charge it at .5 amps. When I am at the track and have something to do, 1 amp. If I am in a time cruch 1C or 1.5 amps. I have the peak sens. set at 6mV and 50mA trickle. So, for the bigger batteries I would charge the Stickman at 2 amps or so, normally charging it at 1 amp. A little guage you can do, when you need to recharge it, put it on for 1 amp (any of them) and when the battery is done, feel how warm it is. It should be warm, but not hot to your finger. Do this when you battery is cool too.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-26-2009, 12:37 PM   #7
If I had kept my Onyx 230 I would have gone for 1/2C, or as close as possible, which would have been 1.2 amps for my Stickman 2500 mah, but because I have a Onyx 200, I use 1A for a slow charge and 2.5A if I'm at the track.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 06-26-2009, 04:17 PM   #8
i have the ballistic 2700 batt. ,i agree to the all post above ,slow is the best i always do the .5a & make sure its warm not hot lol,some guys here simply dont get it they so itchy to run so they do fast charging when it comes to main damn too many complains start blaming the rx batt. slow servo torque & etc. lol ................when it comes to this ,the battery needs attention, the warm rx battery is way to go but not hot battery after charging
mbx5rcr34 is offline   Reply With Quote
Old 06-26-2009, 04:27 PM   #9
what_stanger?'s Avatar
Send a message via AIM to what_stanger?
I charge mine at .7/.8
I would think 1 amp would be okay too, in a pinch....hell probably even higher if you were really strapped for time.
what_stanger? is offline   Reply With Quote
Old 06-26-2009, 05:20 PM   #10
this is 5 amps correct? not half a amp?
dreaux is offline   Reply With Quote
Old 06-26-2009, 05:23 PM   #11
pyromania's Avatar
Trader Rating: 18 (100%+)
Why would you ever think receiver packs should be charged at 5 amps? I'm sure the means .5 or 1/2 an amp.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 06-26-2009, 05:27 PM   #12
cary's Avatar
look at the . in front of the 5 yes .5 = 1/2 a amp not 5.0 amps
so how was transformers
Old 06-26-2009, 05:29 PM   #13
i just got a superbrain. I have been using a wall charger for months i have a orion 1600 and a stickman 2500 for my transmitter. The charger is confusing as hell for me right now and i am a electrician
What amp rate should i charge my 1600 even at .3 isn't that twice the recomended capacity? should it be .16? and the milivolt setting is 5 mv per cell?
Please help.
Old 06-26-2009, 05:31 PM   #14
it was a bad ass movie bro. I liked it better then the first. Special effects were off the hook!! Tons of action! great movie.
Old 06-26-2009, 05:33 PM   #15
cary's Avatar
cool I may have to go
