Old 06-25-2009, 04:36 PM   #1
Gen
Gen's Avatar
Default Mugen leaky diffs ,protek o rings v S5 o rings
i want to know mugen guys who have used protek larger o rings over S5 orings ,how do you get them in ,they are larger to prevent leaking as A main hobbys states .
i can get them into diff case easy but then installing then cup joint on ,im sure it moves up then you have to put the shim on and i get the pin through cup joint but im sure the oring is not flat ,i can tell buy the way the sim shits slightly high 1 side ,,
ANY HELP TIPS SIMILAR TROUBLE ???
Kyosho MP9 tki3
Kyosho Strr Evo
Os engines
Vp race fuel
Futaba 4pks
Gen is offline   Reply With Quote
Old 06-25-2009, 04:42 PM   #2
RCmayor's Avatar
Send a message via Yahoo to RCmayor
Push down one side of the shim and get the pin started. Push the pin in until it stops, then push the other side of the shim down and the pin should slide in the rest of the way. It will be tight at first. Be sure to use some thick silicon oil on the oring.
RCmayor is offline   Reply With Quote
Old 06-25-2009, 06:04 PM   #3
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
The o-rings from Tony's Screws are like that too, but once you get them in, the next time you rebuild it is easier and they are great!
O' and I think you added a "h" to sits
OfnaJoe is offline   Reply With Quote
Old 06-25-2009, 07:23 PM   #4
did they fix this issue with the mbx 6t ? I am looking to buy my first mugen but don' want leaky diffs.
romax is offline   Reply With Quote
Old 06-26-2009, 01:19 AM   #5
Gen
Gen's Avatar
didnt notice i put the h there but it certainly does s_it me trying to get it to sit properly
but back to business ,if i get pin in even if i feel it dosent look right are you saying that should be it ?? ,i just feel the shim dosent look right ?
Kyosho MP9 tki3
Kyosho Strr Evo
Os engines
Vp race fuel
Futaba 4pks
Old 06-26-2009, 01:25 AM   #6
Default nope
nope mate, if i were u , get the mbx6t cause i drives like a dream but get the larger o rings from tony screws. it stops leaky leaky and u dont have to spend wrenching time
muaythai is offline   Reply With Quote
Old 06-26-2009, 04:59 AM   #7
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
The fatter o-rings require you to push on the shim washer to get the pin in the outdrive. Make sure you have good grease on the outdrive shaft and on the o-ring sealing area. Once you the diff together, it will feel notchy till the diff breaks in and the o-rings seat. Its better than having the diff seep oil out all the time with stock S5 o-rings.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 12-08-2011, 07:21 AM   #8
where i can find protek or or s5 or?
turboboost is offline   Reply With Quote
Old 12-08-2011, 08:55 AM   #9
Trader Rating: 15 (100%+)
ProTek: http://www.amainhobbies.com/product_...lacement-Set-8
jqracer22 is offline   Reply With Quote
Old 12-08-2011, 09:01 AM   #10
MadRussian's Avatar
Smile
We sell the new improved/updated clear Mugen orings and Tonys at www.racemugen.com
MadRussian is offline   Reply With Quote
Old 12-08-2011, 09:04 AM   #11
MadRussian's Avatar
Oh and on another note, don't overfill the diffs, just over the top of the crosspins
Old 12-08-2011, 09:29 AM   #12
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
I run these with no problems in my MBX6. www.mcmaster.com part number: 9396K419
You get 50 for $3.13
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 12-08-2011, 11:37 AM   #13
+ 1
moonie1 is offline   Reply With Quote
