One of my shocks is not working. Help?
Seems like one of my shocks is having a problem. The front-left shock seems to be bent or something similar. It will not press together, it is locked in it's position. A closer examinition showed that a part of the sticks that move together is not right.
Check attachment picture. What is the problem?
Rebuild all of your shocks
I can't believe you needed help on this one
It is pretty obvious.
Thanks for the replies. Taking this shock apart, I found out that the screw at the top of the shock was very tight. Is it safe to heat it up with a hairdryer before removal?
Sorry, but what are the "o-rings" and "spacers"? :P
O rings keep oil in, and dirt out of the shock but alow the shaft to move up and down. What car is this? I wouldnt heat it up, only if I couldnt get it out. What type of screw it is and where?
The screw is a hex screw. The RC Model is Losi LST Super Truck. I have the experience with stuck hex screws, that if I apply a lot of force, it will damage the screw. So, because I don't want to do that, can I heat it up?
Hmm.....When I rebuilt my Muggy shocks with aluminum caps you need to take that screw out. If you can't get it out, heat it up a bit and take the short side of the L and put it on the screw, use pliers and turn it counterclockwise. I remember it coming out easy but I had better tools.
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
That's a bleeder screw, to bleed air out (or in) you don't really have to remove that. The whole top of the shock should unscrew from the shock body.
(hmmmm... maybe I am wrong... see Chris's post above mine.)
