Old 06-24-2009, 07:25 PM   #1
Krawlin's Avatar
Send a message via AIM to Krawlin Send a message via MSN to Krawlin Send a message via Yahoo to Krawlin
Default OFFICIAL Picco Engine Thread!
Just thought I would share this with everyone, just got my Picco P3-28 for my Mugen MBX5-T, and I am very impressed with this engine so far. It is the best engine I have ever owned (Only had crappy RTR engines before) and it blows them all away. It is finishing up the initial heat cycle break in, and I am on tank 8 right now. Getting up to about 1/2 throttle to 3/4 throttle max so far. Might not be able to tell very well in the video, but it actually idles really slow but consistent. Temps are also very consistent.
And I am running a Dynamite 086 pipe.
Also using an ODonnell hot glow plug.
Here is the vid -
Any input/constructive criticism is appreciated! Thanks!
Getting out of the hobby, it was a fun 10+ years but time to move on!
Krawlin is offline   Reply With Quote
Old 06-24-2009, 07:27 PM   #2
Trader Rating: 27 (100%+)
I have one too, seems to provide a lot of power for the dollar. I'm barely 1/2 gallon through though
spawn_x is offline   Reply With Quote
Old 06-24-2009, 07:38 PM   #3
Krawlin's Avatar
I had read alot about this engine before I bought it and alot of people said the same thing you did, alot of bang for your buck as far as power goes. To be totally honest, even though I am not running it really hard, I am getting some impressive runtimes of about 15 to 18 minutes (I think, I haven't timed it so I am not totally sure) of just easy driving. Seems to be a good match for my MBX5-T.
Old 06-24-2009, 07:42 PM   #4
that's good news for me. my run-times have been pretty bad but it is running on the rich side still
how much fuel you have through it? I'm still having to heat mine up so the starter box could turn it over
Old 06-24-2009, 07:50 PM   #5
Gearhead racer's Avatar
I love the Picco motors! I have the P7 Evo 3 .21 on my buggy and you can feel the POWER!
Tyler
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 06-24-2009, 07:56 PM   #6
Krawlin's Avatar
Yeah, I have been able to lean mine out some, but I am at a high elevation (4600 feet) so I have to run leaner settings.
I think I have about 1 quart, or 8 to 9 tanks, or something around there.
And alot of people have told me you should always preheat your engine before starting it. I just use some old hair dryer and heat it up to about 150* to 170* then fire it up, starts right after I pull the trigger on the drill (I use roto-start).
To Gearhead racer - I really like mine so far, I think I will be sticking to Picco based engines for a long time. They seem like a really good "bang for your buck" engine.
Old 06-24-2009, 07:57 PM   #7
slumlord's Avatar
You guys have a track down there in Sierra Vista? I used to travel there for work all the time, it's a nice little city.
Jay Stuart #66
slumlord is offline   Reply With Quote
Old 06-24-2009, 07:58 PM   #8
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
Nice vid, those things never get posted here, haha.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 06-24-2009, 07:58 PM   #9
Krawlin's Avatar
Actually we don't, I wish! I go up to Tucson to the HobbyTownUSA to race.
Thanks!
Old 06-24-2009, 08:05 PM   #10
Mine is my first picco and ill have to agree with you. I think ill be sticking with them for a lont time.
Tyler
Old 06-24-2009, 08:23 PM   #11
Krawlin's Avatar
Just found out mine is like a 9 port. Here are the stats from the place I ordered it from -
http://store.socalcrew.com/index.php...products_id=22
CARB TYPE SLIDE CRANK SG Shaft
CONSTRUCTION ABC
ENGINE CASE SIZE .21 ENGINE
BORE SIZE .28
TYPE REAR EXHAUST
PORTS 9 ports
DISPLACEMENT .28 c.i., 16.8 stroke
CRANKSHAFT Heavy Duty Crankshaft 14mm
CARBURETOR Composite, 8mm insert, changeable
PLUG TYPE Standard Plug
On AmainHobbies, the current Picco P3 is only 8 ports. Do you normally count the exhaust port? If not, maybe this place does. Not real sure. And the head on my Picco has all of these etched designs on the top, and the current Picco P3-28's don't have that. Maybe mine is an older version or a newer version? Maybe a bit different?
Old 06-24-2009, 08:41 PM   #12
Trader Rating: 11 (87%+)
Send a message via AIM to wild yfz 450
Sounds really good, nice video!
wild yfz 450 is offline   Reply With Quote
Old 06-24-2009, 08:43 PM   #13
Where did you find that online store?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-24-2009, 08:43 PM   #14
Trader Rating: 7 (89%+)
I have this engine too! Modified by Mark of Powerhouseracing. He modified the porting and has the most unique crank shaft modification (turbo Crank). He Broke it in and tuned it for me. I am from Manila Philippines so it was tuned from the other part of the world. I just adjust the needles if needed by an hour or two. It was tuned a little fat so that i can still run it a little more before race tuning.
This engine is a monster! Sounds like no other down the straight. I geared up so I can drive it. I used 15 or 16 CB and softer clutch spring like a .90 0r 95. Otherwise ill just spin the wheels everytime i put my heavy finger on the throttle.
Mark Recommeded the engine to me cause in stock form its very reliable and cost effective.
oggietiu is offline   Reply With Quote
Old 06-24-2009, 08:47 PM   #15
Krawlin's Avatar
Thanks!
Thanks for finding that for me BTW.
Good to know! I may end up gearing up as well, because it really has alot of wheel spin right now.
TEAM LOSI LST official thread stevenmichael Monster Trucks 1235 Yesterday 03:44 PM
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
Truggy Official Thread!!! Nitro21 Monster Trucks 940 07-14-2012 03:31 PM
*OFFICIAL* Marine Parade RCMC Singapore Thread X4 Singapore R/C Racers 80 12-24-2009 09:24 AM
Official xxx-nt sport 2 thread LOWGEARED Electric Off-Road 225 06-28-2007 09:23 PM
OFFICIAL THREAD FOR GAS POWERED MINI CARS, TRUCKS & BUGGIES VR2L_DUDE Micro and Mini Scales 26 12-13-2006 08:39 PM
