Old 06-24-2009, 06:53 AM   #1
Default associated big bore qustion--help!
just got the big bores from AE they did not come with the bleeder screws though.i need to know if i can use the old one or do i even need them with these shocks.also i would like to know if the shock boots are suposed to suck in when the shock is compressed or does this mean air is getting in and somthing is wrong,of course there was no fluid in the shocks when i compressed them,if i add fluid will that stop or whats the deal.
bigguyrc8 is offline   Reply With Quote
Old 06-24-2009, 07:16 AM   #2
triplesix's Avatar
no bleeding screws are req'd for the big bores!
just build them like shown in the manual - no need to worry about the shock boots.
you'll love these shocks - hands down!
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 06-24-2009, 07:30 AM   #3
Shane Racer's Avatar
I make a VERY small slit in the boot so it will not balloon when compressed and will not collapse when pulled out.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 06-24-2009, 07:36 AM   #4
thanks,whats the scoop on the shock oil weight i heard u can run lighter ,so i think i;ll go with 30 front and 20 rear, with bronze front and silver rear springs any thoughts
Old 06-24-2009, 07:41 AM   #5
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
Try the 1.3x8 pistons 30w oil front and rear.
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 06-24-2009, 07:46 AM   #6
joey ,the shocks came stock with that 13 piston than there is another with no holes am i supposed to drill them or what i have no idear what or how to do this
Old 06-24-2009, 08:10 AM   #7
Drill two extra 1.3mm(.051) holes in the current 1.3mm x 6 pistons you have now.
Also make some 1.1mm (.043) x 10 hole pistons for hard packed tracks.
Old 06-24-2009, 08:14 AM   #8
Also one side of the piston has 6 center punches and the other side has 10. This will help you drill the holes better.
Or you can just order the GHEA pistons from TKO, this is what I use. Plus the team guys run them so your hole diameters are the same as theirs.
http://tkocompetitiondev.com/advance...a21c59&x=0&y=0
Old 06-24-2009, 08:15 AM   #9
ok let me see if i get it-leave the stock ones like they are,than with the extras(that came in the kit)drill 2 more holes in each.than get some more and drill those to what u said for hard tracks
Old 06-24-2009, 08:34 AM   #10
The stock pistons should be pre-drilled for 1.3mm x 6. So just take a 1.3mm (number 55 drill bit) and drill 2 extra holes in them. So now you have a set of 4 pistons that are 1.3mm x 8.
Then take an extra set of 4 blank piston and drill 1.1mm (number 57 drill bit) x 10 holes. Then you'll have a set of 4 1.1mm x 10 piston also.
These are the two setup I normally use, I may change my oil 2.5w-5w depending on the track. But this is a good starting point every time.
Setup 1 (bupmy soft tracks)
1.3mm x 8 front & rear
30w front & rear
bronze front & black rear
Setup 2 (hard packed tracks)
1.1mm x 10 front & rear
30w front & 25w rear
Old 06-24-2009, 09:31 AM   #11
thanks for your time joe take care ,thanks to everyone
