Air filter
#16
Trader Rating: 45 (98%+)
Yeah, same track. Weather is same and ~30-32C. Same fuel and i temp it about 3/4 tank of fuel left.........Will update you all if i manage to run this weekend.
#17
When an engine is ingesting much less than optimum volumetric efficiency, the fuel delivered for that amount of available air is too much, hence the rich or over-saturation of fuel to air mixture.
It could increase operating temperature in two ways:
First, by over loading the engine (inadequate power production to move the vehicle)
Second, in total loss oiling system engine, by limiting the amount of oil introduced into the engine (because oil percentage per amount of fuel delivered stays the same, less fuel means less oil)
This can be addressed (when caused by using very small venturi) by using fuel with less percentage of nitro, and higher oil content.
Torque level can be increased slightly by increasing static compression (using thinner shim)
Can also be addressed by increasing nitro level but still with higher oil content (but shim stays the same)
Using glow plug with higher heat rating might also help torque production. (Advancing timing)
One of the important factor at play here is volumetric efficiency.
This condition can also happen in high altitude or extremely hot environment.
Most people will need to tune this way when trying to get best fuel efficiency by way of decreasing the inlet diameter of the carb, thus limiting the maximum amount of air into the engine.
When air filter is blocked the effect is quite similar but not in a proportional and measurable value.
so my friends, this is what i think happening in tkhoo's suddenly hot engine, my friend's with over-oiled filter, and me trying to save fuel (hahaha)
Please add what i might forgot to mention, and correct where i got it wrong.
Lets discuss, it's quite a fun topic
To tkhoo: how often do you replace filter with clean one? I change outer layer evey 3 tanks max when track is overly dusty
#18
Hehehehe.......Almost 10-15 tanks didnt change outer layer filter with bandage on it......in dusty track. 3 tanks max and change outer layer is too offen for me...hehehe
#19
Easy what... Buy some replacement foams (3 or 4 set) not so expensive. Oil all and bring to track.
Every three tank change outer, next three tank change both.
Filter cheaper than engine
After use i think it's okay to wash, dry, oil, and re-use.
Just dont over-use it since foam degrades over time when you wash it and squeeze squeeze.
#20
I think safe to assume now that your probs caused by this
#21
Just an input.
To get a better understanding about the problem, eleminate the possible cause one at a time.
Don't do all at once. So you really know what was in effect.
Since your initial tuning was okay to start with, try just changing filter first.
Or don't change filter, but try to tune first
#22
#23
Guys, last weekend was rain in my area so this weekend I will try out and get back to you all.
#25
+1 on use new filters. I never wash a filter the few bucks is well worth the peace of mind that my expensive mill is breathing well. I replace the inner and outer after a race day unless it's extreemly dusty then I might change 1 time on race day in the middle. Whatever you do, do not change the filter before a main and expect your engine to run like it did before you changed the filter because it won't.
#26
#27
Guys, it took too long for me to update you all my problem and finding. I dont have track time for the passed 2 month due to work and raining. Last week I able to retuned and run with clean filter and I managed to lower down the temp. Lately the LHS that I used to bought Sidewinder 25% fuel has stop selling 25% and now they selling Sidewinder 30%. But I have no plan to use 30% and get Maxy 25% which I able. May I know any different between this 2 brand? Thanks.
#28
Ahhhh not again!!!!!
Ok, so you should defiantly oil both layers of your filter with oil, dont listen to anyone who tells you differently.
If you have problems with dirt getting in at the ends of the filter, or you have dirt sticking to the oiled outer filter, run one of these. They are thin cheap dry layer covers you can get on ebay for about $6.00. They are washable/re-usable.
Here is the link where you can find them, or search Nitro Filter Cover. They are kind of hard to find but worth every penny.
Filter Covers
Here is a pic:
Filter Covers
Here is a pic:
#29
I live in an area where the tracks are very dusty and the clay can cake on a filter virtually shutting it off. I do wash filters however I switch them out after ever race. I oil my filters lightly by pouring a couple of drops and working the oil throughout the entire filter. Some will say that working the oil through breaks down the filter, but I throw them out after about a half-dozen races anyway.
One investment I have made that has made a WORLD of difference is I bought an Outerwears cover. I am not sponsored by them and I have no affiliation whatsoever. I am only a extremely happy customer with the way those things keep dirt off my filters. I almost never get dirt on my inner filter ever (RC8 type of filter system)
I would look into the Outerwears.
#30
I ALWAYS change the filter and CB bearings before the main
