Old 09-12-2009, 09:19 PM   #31
fast11970's Avatar
Originally Posted by Cory Kerber View Post
These badboys work!
Hmm, I disagree, I have never had an issue running the outer dry, inner oiled, grease on the ends? I have tried the two ways, and found oiling the outer, bogs the engine down in a long main?
I think the inner is to filter out the fine particals, the outer handles the larger ones, if it is super dusty, add a pre filter (Panyhose) The purpose of the outerwears, is that in a long race, it clogs up before the pre filter (Outer) and as needed you can remove it and get another hundred miles lettin the engine breath,My Buggy does Just fine runnin an oiled inned and a dry outer, if the outer gets fuelie or clogged, I just put on a new one, If you have chased your tune on race day, don't change your AF unless you have to, Your tune Will Change, Clutch Bearings, No problem, ( I change them when I dont like Em No More...Pain in Monkey Arse..) Normally if put 45-60 minutes on the bearings, I change em, other wise, I just check em.
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 09-12-2009, 11:12 PM   #32
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Originally Posted by cheapskate.brok View Post
Where/Who is selling the Maxy's? How's the performance? Wat plugs ur using? Thanks
Maxy ah.....You come back to here then I tell you Performance I havent try as last night heavy rain...so didnt go to track to test the new fuel. But I use it before and feel good too. Will let you know. Running med hot plug as usual
I ALWAYS change the filter and CB bearings before the main
I lazy mah and I also didnt race, just bashing that why use till bad on the CB bearing.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 09-13-2009, 08:32 AM   #33
GSMike's Avatar
Although I am very happy with my current set up, this is another alternative I am seriously looking into.
Does anyone currently run these?
http://www.motorsaver.com/truggy.htm
DIALED-RC HOBBIES
CLOCKWORK RACING ENGINES
GSMike is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
Question on Air Filter Oil Ken4 Nitro Off-Road 9 04-16-2008 03:59 AM
