Old 06-24-2009, 12:49 AM   #16
Trader Rating: 69 (100%+)
Im guessing the rear body mounts for the 2.0 do not bolt up to the 1.0?? I could fab something but I really like a factory look and strength factor.
Sick paint job BTW!!
Paul Whalen is offline   Reply With Quote
Old 06-24-2009, 12:54 AM   #17
losi_racer's Avatar
Trader Rating: 25 (100%+)
just put a 2.0 shock tower on it????
and thanks for the complement, the body cracked at the window, j concepts took it back and are sending me two brand new ones, but no i gotta get my scheme repainted
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-24-2009, 04:03 PM   #18
DezSlash's Avatar
Hmm seeing that you are using this on an 8ightE i wondering how it will work on a nitro powered truck? Will i still be good then almost picked one up today at my lhs.
Companies I support
Hot Bodies*Futaba*Novarossi*JConcepts*Hitec*Upgrade Rc*Kalgard*Sidewinder Fuel*Dialed
Arcor Raceway
DezSlash is offline   Reply With Quote
Old 06-24-2009, 05:15 PM   #19
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Yeah, you will really need a 2.0 rear tower. You shouldn't need shocks because the 1.0 arms use the shock risers to get the correct length. The 2.0 just uses straight shocks without the risers. Anyway, all you should need is the 2.0 tower and 2.0 rear body mounts. This will give you as close to the factory look as possible. You will probably need to cut some off of the back of the body as the 1.0 chassis is 14mm shorter. With it at the correct angle the body will be around 14mm too long. Some simple trimming and some new holes for the rear mounts should get you the look you are going for.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
