Old 06-22-2009, 08:15 PM   #1
Default help with 3.3
this is with 2 gallons of blue thunder through it. It ran great today for about 2 tanks then wouldnt start again. But wouldnt start again. As far as I know this engine has never been ran over 270 and was broke in right. let me know if everything looks ok by the top of the piston.
Revo 3.3
Losi 8ight
Stampedes xl5
rage326 is offline   Reply With Quote
Old 06-22-2009, 08:18 PM   #2
ehames005's Avatar
Trader Rating: 74 (100%+)
Can't tell to much by the pic but if you can get the piston in that position with out any resistance you may have lost the pinch in the engine.
Thank you to my 2017 supporters:
Sworkz--Amainhobbies.com---ProTek Rc---Huston's Engine Service
ehames005 is offline   Reply With Quote
Old 06-22-2009, 08:20 PM   #3
should I put a piston and sleeve in the engine and try again? ill check the bearings also b/c this engine should have lasted longer than this.
Revo 3.3
Losi 8ight
Stampedes xl5
Old 06-22-2009, 08:22 PM   #4
ehames005's Avatar
How far up can you push the piston up into the sleeve?
Old 06-22-2009, 08:43 PM   #5
id say 2mm from the top. I think the problem may have been the sleeve was comin out of the case everything the piston went up. there was a knocking is this possible and if so what is the fix.
Revo 3.3
Losi 8ight
Stampedes xl5
Old 06-22-2009, 08:57 PM   #6
ehames005's Avatar
Was the head loose when you took it apart? But I would say that the pinch may be gone in the engine and if that is so then you would need to have the sleeve pinched or buy a new piston and sleeve.
Old 06-22-2009, 08:58 PM   #7
thanks, think ill do the erp from traxxas or put an OS engine in it. and the head bolt were tight.
Revo 3.3
Losi 8ight
Stampedes xl5
Old 06-22-2009, 09:01 PM   #8
ehames005's Avatar
That was going to me the next thing that I was going to suggest the erp program that Traxxas does is awsome!
Old 06-22-2009, 09:10 PM   #9
And the blue stuff is from BT fuel. Not alot of people like it.....
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-22-2009, 10:50 PM   #10
Rampokker's Avatar
Did this happen everytime you turned the engine over while the head was off?
If so, it means you've still got more than enough pinch left in the sleeve. From the photos it also doesn't look bad at all. There's no pitting of the piston or anything of the sort, and it's not burnt black (which would indicate lean running).
So IMHO, I don't think you need to erp the engine yet. Check the following first:
1. Does the engine keep spinning when you press the start button (i.e do hear the "pop, pop, pop" sound continually)? If not, the one way bearing may be slipping. If the bearing is slipping the "pop, pop" sound will stop and you'll hear the electric motor spinning.
2. When you press the start button with the wand in the car, does both led's light up? This will give you an indication of whether the glow plug is working. The blue wire on the glow plug may not be making good contact with the plug, or the yellow wire that connects to the engine crankase may not be making a good connection.
3. Have a look at what the glow plug itself looks like. Is the coil distorted at all? If the plug doesn't look 100%, then just replace it and see if that helps.
4. Set the carb back to factory settings (which is 4 turns open on the hsn and the lsn flush with the carb housing) and then try starting it again.
Try the above things first and let me know what you find.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45705 08-13-2017 01:43 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 10:10 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 06:38 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
Battery issues RS4Pro2GT Electric On-Road 26 12-24-2008 08:54 AM
2004 Wcorcs Gary Fliegel Canadian R/C Scene 877 09-10-2004 05:54 PM
