Old 06-22-2009, 06:26 PM   #1
Madbrad's Avatar
Trader Rating: 29 (100%+)
Default Replacing the front bearing.
The front bearing is leaking and I was wondering when you replace the front do you normally replace the rear? Also any thing else i should do to the motor at this point?
Madbrad is offline   Reply With Quote
Old 06-22-2009, 06:48 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Its never a bad idea to replace both bearings at the same time. you should also check your compression and your connecting rod as well as the pin on the rear of your crank,and all your O-rings, and always a good idea to seal it up good when you re-assemble it
nothing to see here................................
Jaz240 is offline   Reply With Quote
RC10GT2 thread!!!!!!! nitrosteve Nitro Off-Road 4460 Today 09:45 PM
Mugen JX21 jlinds Offroad Nitro Engine Forum 1448 03-19-2015 07:22 AM
HACKER BRUSHLESS MOTORS ERTRACHTER Electric On-Road 503 02-28-2012 10:15 AM
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 10:04 PM
Procedures for removing & replacing rear engine bearing .21 picco. Loveless Nitro On-Road 7 05-02-2008 09:07 AM
Just finished building her and setting her up! Mk.2 Pro! Scoobs Nitro On-Road 14 06-27-2006 10:17 AM
