Old 06-24-2009, 12:40 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by rcgeezer View Post
Monty, are those your normal shock positions? You're running 1 hole down on the tower and 1 hole in on the arm compared to mine (basically the same laydown angle). My droop is also set at 116mm, so I need to check total compression distance. That positioning would result in LESS overall range of travel for your arms, which might also be a good thing. Thanks!
i like it like that
more buggy like handling
i usually spend a bit of time on setup
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
