Old 06-22-2009, 01:04 AM   #1
chipo's Avatar
Default Do you oil a pre-filter?
Hello.
Some people recommend to oil a pre-filter, some don't!?
So what to do, oil them or not?
Chipo
chipo is offline   Reply With Quote
Old 06-22-2009, 01:06 AM   #2
Default pre filter
Originally Posted by chipo View Post
Hello.
no mate, just oil the inner
muaythai is offline   Reply With Quote
Old 06-22-2009, 01:23 AM   #3
jamiekerr14's Avatar
I do both, cant be to safe.. then run a Underground rc Filter protector thing.. sometimes if really dusty..
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 06-22-2009, 01:39 AM   #4
i don't, no matter how dusty it is.
cheapskate.brok is offline   Reply With Quote
Old 06-22-2009, 02:01 AM   #5
Rampokker's Avatar
I used to oil just the inner filter, but then found that on really dusty days the filter got totally caked up with dirt while the outer filter was hardly dirty. So I then started oiling the outer filter as well, just to be safe. Then I found filter covers, and started using it to prevent the outer filter from getting caked with dirt. Now my filters easily last twice as long as before, and I have the added protection for my engine.
XRAY XB8 - Keep Off 21-4
XRAY XT9 - Elite 8 Off
XRAY XB4 - Tekin RS Pro / Fantom 6.5
Rampokker is online now   Reply With Quote
Old 06-22-2009, 02:44 AM   #6
chipo's Avatar
Do you still oil a pre-filter, now when you are using a filter cover?
Chipo
Old 06-22-2009, 02:47 AM   #7
Rampokker's Avatar
Yes I do. The only reason I'm using the filter cover is to stop dirt from clogging the oiled pre filter. Dirt doesn't stick to the filter cover. So I can go much much longer without having to change filters.
Old 06-22-2009, 04:24 AM   #8
Sam-E's Avatar
Oil the outer filter but only very lightly or blot most of the oil out of it, this way the inner filter remains much cleaner.
TMORC - Official Club for the 1/10th Offroad Electric Worlds, 2012!!
Sam-E is offline   Reply With Quote
Old 06-22-2009, 06:24 AM   #9
killabud's Avatar
I use regular "thick" filter oil on the inner and then this stuff on the outer.
http://www.amainhobbies.com/product_...-Oil-Treatment
Its thin so I can get most of it off by squeezing the filter in a towel. By doing this I can run one inner filter all day and change the outer 3-4 times.
Tom Ulmer Team FISH-DO
---\\\Kyosho MP9 TKI3///---
\\\Futaba|OS Engines|VP Powermaster///
Baby Car!!!!!!!
killabud is offline   Reply With Quote
Old 06-22-2009, 06:49 AM   #10
Yes, I oil both, and every local sponsored pro here does at well
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-22-2009, 07:32 AM   #11
PTP Racing's Avatar
When you dont oil the outer all the dirt passes right through and it cakes up between inner and outer. I oil both and replace the outers after each race and the inners after every other race.
If I was really smart I would use something that washes off like K&N or Rock Oil on the outer and I would be able to clean and reuse them but I would never clean and reuse an inner filter.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 06-22-2009, 08:31 AM   #12
thuren's Avatar
Oil both, but squash the outer pre-filter between two paper towels on a table till you can barely get anymore oil out of it, before installing. Once mine starts to cake up a bit on dusty days, I just scrape off the outer buildup if it gets too thick. You'd be amazed how "caked" the filter has to get before it starts to hurt power too much.
Mugen MBX6, NINJA
Mugen eMBX6, Tekno NEU 1515/1y, Mamba Max
Mod Slash
thuren is offline   Reply With Quote
Old 06-22-2009, 08:44 AM   #13
Trader Rating: 52 (100%+)
I just oil the inner I found that when I oil the outer it attracts more dirt than not having oil on it. most people who have losi's oil both just because thats how they come. I also change just the outer filter every 4 runs if its dusty.
MO
Mo Denton-www.mnkraceway.com
Team Losi
Proline,-Redrock Hobbies-,VP Powermaster fuel,Darkside Designs,Speedy Bills!
fast for an old guy
Mo Denton is offline   Reply With Quote
Old 06-22-2009, 08:55 AM   #14
Trader Rating: 32 (100%+)
it's a two stage filter, IMO if you oil outside it's trapping both large and small particles. clogging it faster restricting air.
I do lightly brushed coat of WD40 if I'm running slightly wet conditions on outer filter to reduce water from getting in the filter, but other than that I keep outer dry.
My filters come as inner and outer set, and cheap.. replace both after full days run, clean both in Dawn after.
devilchrist is offline   Reply With Quote
Old 06-22-2009, 10:15 AM   #15
houston's Avatar
Trader Rating: 91 (100%+)
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
Tungsten Disulfide engine pre breakin Lubricant Relay8039 Onroad Nitro Engine Zone 14 12-28-2010 08:50 AM
What should I upgrade? sokar Nitro Off-Road 35 06-25-2009 02:48 PM
EXTREME RC MODIFICATION - Findings and Discussions mop_iko Nitro On-Road 126 08-20-2004 02:12 PM
