Old 06-21-2009, 10:14 AM   #1
TRXRustler33's Avatar
Default Nitro Help
I have a .28 truggy and it squeels when you give it some throttle i dont no if it is the clutch bell or what but it only does it when it has tires on, but it doesn't when the tires are not on it, it only does it when it is under load.
Team Terribles
Suzuki RM125
TRXRustler33 is offline   Reply With Quote
Old 06-21-2009, 06:23 PM   #2
Gearhead racer's Avatar
Originally Posted by TRXRustler33 View Post
I have a .28 truggy and it squeels when you give it some throttle i dont no if it is the clutch bell or what but it only does it when it has tires on but when the tires are not on it, it only does it when it is under load.
Well... to me it sounds like a bearing issue or a brake setup problem.
Do your tires spin pretty freely when they are on and your truck is turned on( able to run your servos turn wheels throttle etc.)?
Check to see if your brakes are too tightly adjusted, maybe you mite need to adjust them a little. You should be able to role your truck across the floor with no resistance at all.
Does your clutch bell spin freely? make sure your gear mesh is not too tight.
Let me know how you make out!
Tyler
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Adelaide Nitro ON-ROAD NitroRacerSA Australian Racing 786 04-15-2009 07:13 PM
Leisure Hours R/C Raceway 2008 Summer Schedule LeisureHours Wisconsin & Illinois Racing 115 08-12-2008 04:28 PM
Novarossi ,best choice? sac Nitro Off-Road 37 04-06-2008 09:35 PM
PNP HOBBIES & SPEEDWAY rcpaintinpete Florida Racing 677 03-06-2008 11:21 AM
2008 Roar Nationals DustinR Electric On-Road 490 01-08-2008 05:12 PM
