Fioroni Turbo sliding clutch 2007...bogging.
I just purchased a Fioroni Turbo sliding clutch "2007" the one with 50% split carbon shoes.
The clutch came with one hard and one soft springs.
Installation went just fine...and followed some guidelines from another forum for this specific clutch.
The shoes don't hang or anything but i get a nasty bog down low on a high traction track.
I haven't yet tried 2 hard springs but went down on clutch bell size with no luck.
I've seen a few reports on this bog and was wondering what i could do to fix it. Will two hard springs make THE difference?
those clutches will suck the bottom end out of any engine, even a modified picco 28 will suck wind down low with that clutch..... horrible clutch choice if your looking for any sort of low end snap..If your on any sort of high bite track these clutches are unusable no matter what you do......before anyone tries to tell me differently be aware i have several of these clutches and have tried them on many engines, from .21's to modified Picco 28's and OS 28's..IMO they suck bad !!! better off with a M2C setup
Hi Chris,
after using the Fioroni sliding clutch for a very long long time i have to agree and say that if you are looking for racing performance use only standard 3 shoe clutch system.i know it easier to use the sliding one ,it's last's longer etc'...i said the same,but it kill's all engins modifid's or not.
just use standard shoes clutch.
why do you use only Xray bell's?
OK I'm wrong. The fioroni sucks. There is no way you can compete with it, because it kills every engine. Right. That's why I am and have been compeating with it for years.
I don't know. If it's not working for you guys, it's not working. But I have had great success with it, and I am running it in a truggy with a stock v-spec. No modded monster engine, and I still feel I have plenty of bottom end.
on a very slick track i don't mind the Fiorini and have had good results... but on any high bite surface its terrible...nowhere near the snap of a normal 3 shoe, not even close.. I even have some before and after video of a M2C and a Fiorini on the same setup on the same day. the difference is night and day
C'mon Jammin, you know you love it! With the right springs the fiorini has plenty of snap,
I do prefer the original 2 shoe design to the turbo twin.I had a spring snap during a qual yesterday, limped her home and put in the turbo twin shoes and didn;t notice a difference.
That busted spring mangled the shoes but she never stopped running.
Anyway, there is a lot of fioroni love, and there is a lot of hate. I guess it's just a matter of what works for you.
I really don't get all of the fioroni hate. I run the same setup described above on a v-spec in a losi 8T 2.0. I have plenty of bottom end snap. I feel that I have as much or more snap than an aluminum setup. And a clutch that lasts 12 gallons. It is really a mystery to me, how you would need more snap than the fioroni can provide. Especially in a buggy.
carbon will Never grab as hard as alum....its not physically possible.....we all know you love your Fioroni...but i WILL put in my opinion when people ask about them....me and max have done extensive testing and found the clutch to out right suck plain and simple.
if you have the proper stall and proper hardness of shoes you should Not be slagging much if any alum on the bell....either you are running too soft of shoe or too hard of spring and are overheating the shoes and slagging them...IF you mix 2 carbon's with 2 alum's the carbon's will lubricate the clutch and Not allow ANY slag to build up...My Losi 13T on my buggy is like 10-12 gallon's old and it still 26.5mm ID...and on a side note...ive never had the "loose bearing" in my stock losi bell's...ive found the Robinson racing to wear a lot faster then the losi and they were Overly heavy in comparison to stock.
From my experience, the fioroni setup with 2 hard springs grabs better than a losi setup with 4 KHZ 7075 shoes, 2 gold and 2 green springs. That is what I feel is a good baseline aluminum setup, and also a very popular one. To me the fioroni grabs better. With that being said, I know it isn't the snappiest aluminum setup. I have never seen the need for any more snap than the fioroni provieds, in either buggy or truggy on a whole range of tracks. Like I said, run what works for you. The fioroni works for me, and longevety is outstanding, so I will continue to run it.
I ran for years the original slita clutch
with a novarossi engine, no problems fitting
now, I picked up a new fioroni flywheel
and none of the engine cones won't fit , always slips on the crankshaft
what sort of cone/system to you guys use in the end ????
VTI-Chris, try the 2 shoe Turbo Sliding Clutch in the black compound with stiff springs, or the 4 shoe 70/30 split Turbo Sliding Clutch in black compound with any combo of standard and stiff springs. You will have the bottom end snap you are looking for. This is not an opinion, this is based on the extensive testing I have done over the years.
