Old 06-28-2009, 10:29 AM   #31
vti-chris's Avatar
Worked with it and finally i'm on the right way.
After trying the stock springs which resulted in bogging down low i decided to play a bit with the springs until the Hard ones arrive.
I just cut the soft/longer spring to about the same length as the hard/short one supplied with the 2007 version.
Results=night and day.
Bogging was almost gone...and that little left allowed me to get on throttle sooner. I don't know if it was the clutch or not but after a split second of engaging the car was almost doing wheelies, it gave way too much punch just after that little bog. Engine temps also went down to normal.
I'll get back to this as soon as i get the Hard set.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 06-29-2009, 08:29 AM   #32
Integra's Avatar
Originally Posted by zixxer View Post
+1 m2c is the only way to go ...the fioroni is a decent set up if you dont want any clutch m/a
+1 its the easy way out ...a wise man once told me if you want the performance ..you've got to just suck it up and run a stout clutch ...
I concur.
Old 07-20-2009, 03:19 AM   #33
speedy2's Avatar
last races my clutch was stalling bther engine
because the brass shim between clutchbearing
and nut got oval shaped
wonder if I can't just drive it without
see no real need for it..?? does nothing in fact....
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 07-20-2009, 03:27 AM   #34
vti-chris's Avatar
I use the large shim found in the diffs.
Is made of steel and doesn't oval so easy.
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 07-20-2009, 08:49 AM   #35
garen's Avatar
I have run this clutch without the shim, it works fine without it. In fact, when the clutch was first produced, there was no shim included with the clutch.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
