Old 06-26-2009, 03:15 PM   #16
pantera nitro's Avatar
Originally Posted by speedy2 View Post
I ran for years the original slita clutch
with a novarossi engine, no problems fitting
now, I picked up a new fioroni flywheel
and none of the engine cones won't fit , always slips on the crankshaft
what sort of cone/system to you guys use in the end ????
have you shimmed between the back of the collet and the engine casing?
i had the same problem with my fioroni clutch/Redline 5 port and all i had to do was shim it to bring the collet forward (towards the clutch bell) so it allows the flywheel to tighten further back along the collet without hitting the engine casing before its tight enough!
not had a problem since then.
Mike
MP9-TKI2/O.S. 21XZ-B V-Spec Speed
RC8T-CE/MG66X
RC8B-e/Hobby Wing
RC King Hobbies - onlinerc.com.au - Pro-Spec Race Bearings
pantera nitro is offline   Reply With Quote
Old 06-26-2009, 03:26 PM   #17
blktransam's Avatar
Trader Rating: 59 (100%+)
well I have had this fironi clutch sitting in my tool box for like 6 mths never installed it I have been very happy with my m2c 4 show set-up that I have ran for like 1.5 years....so yesturday as I was putting my car back together (had torn down from last race to go through everything as I do every race) I decided to throw in the fironi clutch I am running a bmx6 with a rb ws7-ll got everything back together last night and decided to do a quick test in back yard to see if it had a bog or anything and this clutch straight up rips! I will have a better idea on sunday (race day) but as of right now I feel very confident I will like this clutch set up more then my m2c 4 shoe....
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 06-26-2009, 11:00 PM   #18
vti-chris's Avatar
Which one do you have?
2 shoe, 4 shoe(70-30) or 2007 version 4 shoe(50-50)?
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 06-27-2009, 12:53 AM   #19
speedy2's Avatar
I tried everything
dremeled back the cone end , shim between engine..
still slips on crank fastening
nut to the right side to engage on the threads later...
I have a 2 parts carbon
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 06-27-2009, 04:26 AM   #20
vti-chris's Avatar
The nut that bolts on the crank will fit only one site...the one that has an inner groove inside...this is used to slide over tha end of the threaded crank section.
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 06-27-2009, 06:07 AM   #21
Trader Rating: 61 (100%+)
Originally Posted by Maximo View Post
those clutches will suck the bottom end out of any engine, even a modified picco 28 will suck wind down low with that clutch..... horrible clutch choice if your looking for any sort of low end snap..If your on any sort of high bite track these clutches are unusable no matter what you do......before anyone tries to tell me differently be aware i have several of these clutches and have tried them on many engines, from .21's to modified Picco 28's and OS 28's..IMO they suck bad !!! better off with a M2C setup
+1 m2c is the only way to go ...the fioroni is a decent set up if you dont want any clutch m/a
Originally Posted by vti-chris View Post
The thing is that i prefer carbon shoes instead of alloy.
I use Xray bells and are kind of expensive to waste with the alloy shoes.
if you run an m2c you dont get the wear on the bells that you would on a typical 3 shoe set up ....in other words you dont get the groove in the middle ....try a different bell there are plenty of narrow style bells out there that work just fine on an xray ...i mean 28 bucks for a bell and some bearings is retarded
Originally Posted by danip View Post
Hi Chris,
after using the Fioroni sliding clutch for a very long long time i have to agree and say that if you are looking for racing performance use only standard 3 shoe clutch system.i know it easier to use the sliding one ,it's last's longer etc'...i said the same,but it kill's all engins modifid's or not.
just use standard shoes clutch.
why do you use only Xray bell's?
+1 its the easy way out ...a wise man once told me if you want thhe performance ..youve got to just suck it up and run a stout clutch ...
try shims behind the collet and also use a losi collet ..the are short and stubby and they will work
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 06-27-2009, 06:12 AM   #22
speedy2's Avatar
it's the cone that doesn't grab onto the crank...
why on earth they had to change that..
the old one is going like that on all my engines without shim
or anything else...
Old 06-27-2009, 06:16 AM   #23
get a losi collet
LATER COOKIE
TEAM PROLINE-RACING
Old 06-27-2009, 09:50 AM   #24
speedy2's Avatar
don't see any losi collet alone for sale..
Old 06-27-2009, 02:16 PM   #25
here ya go
http://www.amainhobbies.com/product_...Collet-Spacers
LATER COOKIE
TEAM PROLINE-RACING
Old 06-27-2009, 02:19 PM   #26
figured i would post this ...when i had problems with bottom end this what mr fioroni sent me
LATER COOKIE
TEAM PROLINE-RACING
Old 06-27-2009, 02:37 PM   #27
speedy2's Avatar
thank you sir
Old 06-27-2009, 03:14 PM   #28
Jammin you dont know hate/flak. Try mentioning you run a Werks clutch,then even the fioroni guys start hate.BTW have you ever noticed the script on the Werks clutch that says made in italy?
butch man is offline   Reply With Quote
Old 06-27-2009, 03:41 PM   #29
Maximo's Avatar
That is an interesting read...I have tried the Turbo sliding clutch as well as the TT2007...both these clutches never worked correctly in truggy for me, i do however run the turbo in my mod 28 powered DM-1, the low engagement and lack of snap make my car easier to drive..... Now I have yet to try the Twin turbo and am now wondering if it may perform better in a truggy then the other 2 clutches did..... I guess i will order one and give it a try, I didn't realize the Twin turbo was better for a heavier vehicle, i had been running the TT 2007 instead... I wish A-Main would have a description of what each clutch is intended for
Maximo is offline   Reply With Quote
Old 06-28-2009, 07:46 AM   #30
tristyn's Avatar
Default fioroni
I have been running the Fioroni clutch for a few yrs. with good results. I do only run the 70/30 split on both truggy and buggy. This clutch set up allows for 3 springs, 2 in the 70% side & 1 on the 30%. This set up gives you a little better tuning option while using standard or stiff springs. This clutch has always grabbed awesome for me.
tristyn is offline   Reply With Quote
