Old 06-20-2009, 03:49 PM   #1
Jaz240's Avatar
Trader Rating: 52 (100%+)
Default Boca bearings Green Seal Opinions wanted
Who has tried these. are they really maintenance free? Do they work as claimed. Can I get a whole season out of them without cleaning/lubing/replacing
I clean my car with a hose/brush/ simple green and an air compressor, then WD-40..will they hold up to the water, and air?, or will I just pay 3 times the price and have to throw them away after 1/2 gallon of fuel like the Avids/answers?
Looking for first hand personal experiences only, not guesses..Thank you
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-20-2009, 07:41 PM   #2
scapbell7's Avatar
Trader Rating: 18 (100%+)
I run the boca ceramics. I also use about the same cleaning method you use except the water. I have been running them since Jan. I clean my car ( take every thing off of the chassis) after every race and every other practice. Mine still feel very smooth and tight. I had several people tell me not to waste my money but I do not regret buying them, every one will have there opinions about it but if I have the cash I will run em. I also try to clean the outer parts of the bearings with lube and air when I clean my cars.
scapbell7 is offline   Reply With Quote
Old 06-21-2009, 10:01 AM   #3
Jaz240's Avatar
Thanks for the input, anyone else?
Old 06-21-2009, 10:47 AM   #4
smracer31's Avatar
Send a message via AIM to smracer31
stop using water to clean your car, use simple green
smracer31 is offline   Reply With Quote
Old 06-21-2009, 10:56 AM   #5
Jaz240's Avatar
LOL, Thanks, I use both, I dont spray water on the bearings..just the plastics
Old 06-21-2009, 11:16 AM   #6
scwrod's Avatar
The first ingredient of SG is water. It also has the same evaporation rate as water. Because it is a water based product metal will begin to oxidize and rust.
If you are going to get away from water altogether, just use alot of wd-40 and air. I have noticed that WD-40 can be hard on a switch. I put a silicone cover over my switch and took care of that.
I have tried all methods.
Water- I never saw any damage or accelerated parts wear when using water. I would hose it, SG, hose it, douse it with WD-40 then hit it with the air compressor.
No water- air,WD-40,let sit a few minutes, air, wd40, let it sit, air and then just wipe it off as I am working on it.
I also have a parts cleaner with a pump on it. I tried kerosene, worked good just to smelly. Gonna try it with WD-40. I just need 5 gallons
I am also gonna try a new attachment to the air compresser, Air and Cleaner at the same time. Will probably try a SG, WD-40, alcohol mix. This seems like it will be the best and quickest way to get the job done.
Oh, I almost forgot. I use Boca Bearings and love them, even though they are not indestructible.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 06-21-2009, 11:23 AM   #7
YoYoMoFo's Avatar
I have tried the Denatured Alcohol in a spray bottle. It evaporates before you can actually clean anything with it, plus it pretty much makes your plastics look worse because of the horrible white film it leaves behind
YoYoMoFo is offline   Reply With Quote
Old 06-21-2009, 01:34 PM   #8
aaron joy's Avatar
Trader Rating: 16 (94%+)
I use the Green Seals and prefer them over the Ceramics. I have tried both. My Ceramics did not last nearly as long as the Green Seals and I take very good care of my equipment. Just remember it is still better to use metal shielded in the clutch area, the rubber seals create more drag and heat.
aaron joy is offline   Reply With Quote
