Old 06-19-2009, 10:17 PM   #1
Send a message via AIM to Roadrunner01
Default Jato 3.3 wheelie?????
I got a new jato 3.3 about a week ago and I can't get it to do any wheelies....any reason why this might be? I'm new the whole r/c world
Roadrunner01 is offline   Reply With Quote
Old 06-19-2009, 10:21 PM   #2
Lean the LSN and HSN. Read the tuning bible at the top of the page.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-19-2009, 10:40 PM   #3
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
lean the high speed needle alittle
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 06-20-2009, 07:57 AM   #4
markr04's Avatar
I had that "problem" with mine a while back.
1) Your engine isn't up to peak performance until you've got a gallon or so fuel through it.
2) The stock tires may not be gripping on the surface you're running on. Jaco makes some supposedly good foam tires, but I haven't tried them.
3) Check your differential. Mine came from the factory with no diff fluid in it, just some grease. After I put 10k diff fluid in it, it took off better (at the expense of turning traction).
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 06-20-2009, 07:58 AM   #5
do the above and get a smaller clutch bell if wheelies is all you want to do.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 06-20-2009, 09:10 AM   #6
Should I also get a bigger spur gear? And what size
Old 06-20-2009, 09:16 AM   #7
markr04's Avatar
Get your engine (further broken in, and tuned) and traction (differential, if needed) taken care of first.
If it still isn't wheelie-ing, do one or the other with the clutchbell/spur. Going down on your clutchbell has the same effect as going up on the spur gear.
Old 06-20-2009, 09:29 AM   #8
Thanks for the help I will give it some more time to break in
Old 06-20-2009, 10:16 AM   #9
Autie's Dad's Avatar
Stiffen the rear shocks as much as possible. You will notice right above the spring there will be a collar. Screw that down to make the spring tighter. Your car may not handle as well but you will be doing wheeliees
Bruce Bender
Cigar Powered Nitro Losi 2.0
One Hobbies
Autie's Dad is offline   Reply With Quote
Old 06-25-2009, 09:30 AM   #10
I would disagree the jato has a lot of power for that small truck i would say tighten the slipper clutch a little....
B>R 808 is offline   Reply With Quote
Old 06-25-2009, 09:33 AM   #11
Dude just lean it out - watch the video that comes with it and it will tell you everything you need to know-
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
PICS OF YOUR RC NITRO OFF-ROAD CARS busta774 Nitro Off-Road 391 07-02-2010 04:01 PM
Traxxas Jato 3.3 NEW NEVER RAN o.s .18tm motor! rustlerbasher09 R/C Items: For Sale/Trade 23 06-29-2009 03:48 PM
Tags
jato, jato 3.3, wheelie
