BCE PMB6 MBX6 Chassis!
#17
yup its me. Dang it you caught me.
#18
I got a new one for sale here: http://www.rctech.net/forum/r-c-item...e-chassis.html
I dont run Mugen anymore so if anyone needs one right away let me know.
Albert
Albert
#19
Just a note as to what I found after installing my BCE chassis. I left the settings just as I had when running the stock chassis.
The car felt happier once I dropped the shock weight one step. For example if running 450fr/400rear, go to 400fr/350rear.
The chassis seems to have increased stability more than any one thing. The rigidity versus stock also seems to improve the steering.
Fit was perfect.
I received my chassis after 5 weeks after ordering.
I also put one on my mbx6t, but I do not see as big a difference in the handling (but thne again it is a truggy).
Bottom line, well worth the investment.
Fit was perfect.
#20
Does it fits the long chassis MBX6R?
#21
#22
Anyone has any problems getting the front lower brace of the front bulkhead to fit onto the BCE PMB6 chassis? I measured the width at the front of the chassis, the stock is 43.2mm and the BCE is 44.1mm. It's slightly wider than the stock 6R chassis so I can't seem to use this chassis. The rear hardly fits as there is almost 0 tolerance. I would have to really force it in and would have a terrible time getting it out. Anyone has any advise? Btw it's a 6R I'm trying to fit this chassis to. But I thought other than a longer rear center drive shaft, the whole front and rear end of both the 6 and 6R should be the same?
