Old 06-19-2009, 02:10 AM   #1
dirtyboo's Avatar
Default damaged bearings
hi guys,
i recently bought a new OSspeed 21 vzb spec2 for my 1/8 buggy. did the normal break-in process. after break-in run a few tanks ther was unexpected noise coming from the crankshaft. i open the engine n found out the rear bearings has no freeplay as i turn it wit my fingers. i assume that the bearings was damaged.
this engine is using ceramic bearings for the rear. somebody told me i shld not use after-run oil for ceramic bearings, some say that is not true.
change the rear bearings to a new one but is steel bearings cause the ceramic was out of stock. everything is running fine now,no funny noises from crank.
somebody told me i wil loose 10% power cause of the steel instead of ceramic bearings. but wen running it wit the steel bearings i did not feel any difference, mayb cause im stil new at this hobby.
my questions:-
1. did the after-run oil damage the ceramic bearings?
if not wat was the cause of the damage?
2. wil i loose power cause of the steel instead of ceramic bearings?
if loose power by how much?
mugenseiki mbx-6, mugenseiki mbx-6t, hpi savage x 4.6, hpi savage flux, tamiya tb-03, kyosho v-one rrr evo 2 wc edition, kyosho dst
tt raptor 50 titanium, align 450 sports, e-sky honey bee
dirtyboo is offline   Reply With Quote
Old 06-19-2009, 06:40 AM   #2
you won't notice a power difference but when its time to change it again I would go back to ceramic. I dont think you messed up anything with aro.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 06-19-2009, 09:16 AM   #3
Peter Martin's Avatar
You cannot damage a ceramic bearing with any oil. It always makes me laugh at how many "Bearing Engineers" are out there. The real difference is not power but spool up and no dips in RPM because the ceramics do not cause a frequency that can drop RPM. Also they run cooler and last longer.
If you need any bearings let me know.
www.tkocompetitiondev.com
Peter
909-256-4064
Peter Martin is offline   Reply With Quote
Old 06-19-2009, 09:56 AM   #4
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Peter
909-256-4064
^^^^^BEST BEARINGS MADE.
OfnaJoe is offline   Reply With Quote
Old 06-20-2009, 01:10 AM   #5
dirtyboo's Avatar
u guys r right, the aro is not the issue. how can lubricants damage some bearing. some people wil say things that they r not 100% sure bout, those bearing engineers...
stil wondering why it was damage. can this happen to new engines?
anyway, i wil b using the steel bearing untill it wears off then will change back to ceramic. thx for the info guys!
Old 06-20-2009, 07:59 AM   #6
Bearings just wear out and sometimes sooner than others.
Old 06-20-2009, 01:56 PM   #7
OfnaJoe's Avatar
Peter
909-256-4064
Peter, can you post up the engine bearings for a OS V-Spec in ceramic for me?
I went to your site and can't find them!!
Thanks Joe
Old 06-20-2009, 01:59 PM   #8
OfnaJoe's Avatar
Found them at A-Main, but out of stock on the rears
Old 06-20-2009, 09:16 PM   #9
We have them in stock Joe. Just sent a bunch to A Main.
Front CB-607C2RS
Rear CB-MR25414
Old 06-21-2009, 04:22 AM   #10
OfnaJoe's Avatar
Thanks Peter !!
1/12 forum ovalnator Electric On-Road 45708 Yesterday 11:08 PM
TRF414M, 404x, 414, 414X TRF-Powered Electric On-Road 3575 07-22-2017 07:54 PM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 06:15 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
xray4life / Marcus Malone...just another Farmington, MI sneak-thief Scottrik Buyer/Seller dispute and Feedback discussion forum 62 07-29-2007 05:31 PM
