Old 06-19-2009, 05:38 AM   #16
B.A. Racer's Avatar
mine work great..no problem with them so far
Brad Abtey
Team Associated | Reedy | JConcepts | Infamous Designs | PitBox Hobbies | Shady Apex
"Anything in life worth doing, is worth overdoing."
B.A. Racer is offline   Reply With Quote
Old 06-19-2009, 10:41 AM   #17
xxxtcr's Avatar
Trader Rating: 15 (100%+)
so we're lookin at 37 bucks to replace all the gears when all i need is the plastic gear on the 351, does anyone know if you can just get the one gear you need?
xxxtcr is offline   Reply With Quote
Old 06-19-2009, 10:51 AM   #18
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Yes you can, in a 5 pack too. Here.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 06-19-2009, 11:15 AM   #19
xxxtcr's Avatar
thanks for the link, that will be much gooder than 37 bucks a pop
Old 06-19-2009, 11:19 AM   #20
Regional Moderator
I need to double check that those are the right ones for the BLS...
Jon Carlson
Old 06-19-2009, 11:23 AM   #21
Regional Moderator
Ok, just called and those are NOT for the BLS. Sorry, but if it's still under warranty send it in, they will take care of you.
I've also got someone checking on single gears for the BLS series.
Jon Carlson
Old 06-19-2009, 11:26 AM   #22
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
you can order just the plastic gear from hobbico. I did.. The gears are only like $1 each but shipping is $10 so i would order more then 1
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 06-19-2009, 01:37 PM   #23
xxxtcr's Avatar
bummer, I already ordered the gears oh well, I'll see about ordering the ones I need from hobbico
Old 06-19-2009, 07:45 PM   #24
Regional Moderator
You have PM about the 5 pack I suggested you get.
Jon Carlson
Old 06-20-2009, 07:29 AM   #25
Send a message via Yahoo to windellmc
Usually when that plastic gear goes you have no steering. You really need to get that servo apart and figure out which gear is actually bad.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 06-22-2009, 05:03 PM   #26
lucky2's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to lucky2
Default chattery servos bls
ok fellas i also ran into this problem it was not from broken plastic gear it was from the grease buildup on all of the gears check this out first clean them all put white lithium under plastic gear and put some lithium on all metal gears but be sparing not to over grease put back together i bet problem will be solved or busted gear.
lucky2 is offline   Reply With Quote
Futaba 4pk, lipos, brushless motors, esc, servos for sale weaponx R/C Items: For Sale/Trade 53 08-31-2009 07:00 AM
