Old 06-18-2009, 01:50 PM   #1
losi_racer's Avatar
Trader Rating: 25 (100%+)
Default rebuilding an engine
ok guys, i know to rebuild an engine im just having trouble.
i have an os vspec that im doin rod and bearings
im tryin to take the c clip out of the piston to take the rod out but it wont come out. both sides dont curl in the center, ive used exacto blade, a pic, and a needle. any ideas?
EDIT:
ok i FINALLY got it out but now i have an issue, i was getting the bearings out and the back of the exhaust hole broke on the case, will i have to get a new case? heres pics it not bad
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-18-2009, 02:32 PM   #2
losi_racer's Avatar
new problem
Old 06-18-2009, 02:35 PM   #3
How da heck did you do that?!
Yes new case is needed.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 06-18-2009, 02:37 PM   #4
losi_racer's Avatar
the rear bearing wasnt coming out, it actually burnt the rear bearing.
after 20 min of being in the oven i tried forcing the bearin out, it was stuck have way out but it wasnt going. so i put it back in not wanting to mess the case up and i pulled it out about 5 min later and smacked it on my hand, bearing came out, but a piece of the case was in my hand as well
Old 06-18-2009, 02:40 PM   #5
Wow. That's wild.
20 minuets sounds like a long time in the oven. I left mine in 10min and the rear being came loose. I did it on a nova though.
Old 06-18-2009, 02:41 PM   #6
losi_racer's Avatar
Originally Posted by Alan D. View Post
Wow. That's wild.
i know, i dont know why it didnt come out. ive rebuilt about 4 motors so far and this is the first one it didnt come out after 10 min
should i get the speed case or reg?
Old 06-18-2009, 02:43 PM   #7
cary's Avatar
Trader Rating: 67 (100%+)
i will go out on a limb say that a new motor is in your future
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 06-18-2009, 02:44 PM   #8
losi_racer's Avatar
this motor has given me so many issues its unreal. but i have everything new for this now except a case and a cooling head
Old 06-18-2009, 02:54 PM   #9
Jaz240's Avatar
Trader Rating: 52 (100%+)
I have a spare case Doug $50, you can pick it tomorrow with the Tire balancer
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-18-2009, 02:55 PM   #10
vladconnery's Avatar
Trader Rating: 35 (100%+)
First I'm not flaming OS engines. However there cases have been suspect for a long time. That rear bearing should have fell out after 10 mins at 350 degrees. I just did 2 piccos and a Jammin and no problems with rear it always just fell out. However with the fronts you might have to use a little force not much.
Actually I'm for one glad to see you rebuilding it. Theses engines can be rebuilt time and time again as long as the case is in good shape. A dollar saved is a dollar saved no matter how you slice it.
P.S. Don't put your bearings in the freezer before you install them. It's not necessary and a real dumb idea. What happens when metal goes from below freezing to above 200 in seconds.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 06-18-2009, 02:55 PM   #11
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
The speed case is the same junk... i would get a JX case
http://cgi.ebay.com/Mugen-Ninja-JX21...3%3A1|294%3A50
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 06-18-2009, 05:44 PM   #12
Taylorm's Avatar
......just did just that in my mega on-road motor......the wrong way is to force them in with a press/puller......you are wearing out the case....freeze them for 24 hours in a zip loc bag....heat case to 300 or so on a hot plate....put bearings on crank and they should drop right in with no force at all....it's called interference fit......
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 06-18-2009, 05:58 PM   #13
easyryder's Avatar
Dont waste your tme rebuilding these tiny engines.
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Old 06-18-2009, 05:59 PM   #14
Jaz240's Avatar
You both make very valid points. Now I am curious as to which way is better
Old 06-18-2009, 07:03 PM   #15
mauromj's Avatar
Trader Rating: 20 (100%+)
So if I worked with these engines, then would rebuilding a regular car sized motor be wasting my time? Should I just buy a whole new motor everytime?
http://people.bath.ac.uk/ccsshb/12cyl/
mauromj is offline   Reply With Quote
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
MAX POWER ENGINES Secret_weapon Onroad Nitro Engine Zone 334 08-29-2010 09:54 AM
Practice on a race motor? wick3dr00st3r Nitro Off-Road 24 01-09-2009 03:50 PM
5 cell in 27t/19t MR JOLLY Electric On-Road 451 03-15-2007 09:12 AM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
