Old 06-20-2009, 02:47 PM   #31
Jaz240's Avatar
Trader Rating: 52 (100%+)
If i doesn't expand the case Dreaux, it will grind the case every time you pull out and/or put in a new bearing it be slightly looser, and eventually it will not hold tight..That's why I am so curious as to how it works
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-20-2009, 03:04 PM   #32
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Jaz240 View Post
Now you need to explain, how the GRP thingy gets the bearings out without expanding the case? The case is what holds the bearings in place
You have my interest. Please go on
It is a puller. It clamps the bearing from the inside and pulls it out without heat. Just like the tools that engine builders/factories use. It really won't hurt the engine. How many times are you going to remove and install bearings? You can also heat the block up some when you do it if you feel it is nessicary.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-20-2009, 03:15 PM   #33
Jaz240's Avatar
ok so it works like a flywheel puller but its made for bearings. i would think its really hrrd to get them in and out without heat...looks and sounds like it worth the $$ though..thnx bud
Old 06-20-2009, 04:01 PM   #34
It's actually VERY easy to get them out without heat. I can change bearings in an engine from start to finish in about 10 minutes(assembly and disassembly of the engine included). The tool does all of the work. You just turn the wheels and the bearing will pop out.
http://www.losi.com/Products/Feature...rodId=LOSR0050
-Koby Kubrin-
Old 06-20-2009, 04:08 PM   #35
Jaz240's Avatar
Me likey..I'll ask Billy Fischer to get it for me..I am sure it wont be $180..ouch
Old 06-20-2009, 04:21 PM   #36
Yeah the price tag does hurt. It used to be available for cheaper at some of the online places, but noone seems to be carrying it anymore. Better hurry if you want one. GRP is no more(as far as engines go).
-Koby Kubrin-
Old 06-21-2009, 05:48 PM   #37
Trader Rating: 15 (100%+)
If you have everything to put it all back together with i wouldn't think that little chip would hurt anything. It did not go all the way down to the case and the exhuast gasket will seal that off. Just make sure to put a couple of pipe springs on to keep it nice and snug. But if i had all the stuff i would definately try it. If it goes to lean bogging like you don't have the pressure line on then you know it's not going to work. But from looking at the pics i don't see any problem with it not sealing off.
Jonathan Bell is offline   Reply With Quote
Old 06-21-2009, 05:54 PM   #38
oh yeah and the grp engine tooling kit is the best money i ever spent it rc. I am seriously thinking of trying to pick up another set just because they won't be out there much longer. Worth every penny!
Old 06-21-2009, 06:02 PM   #39
alexrckid's Avatar
over the course of time, i've done bearings on plenty of engines(italian, japanese, etc.)........i use a heat gun(not a hair drier).......have never had a bearing(front or rear) that has given me a problem.........removing of installing
alexrckid is offline   Reply With Quote
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
MAX POWER ENGINES Secret_weapon Onroad Nitro Engine Zone 334 08-29-2010 09:54 AM
Practice on a race motor? wick3dr00st3r Nitro Off-Road 24 01-09-2009 03:50 PM
5 cell in 27t/19t MR JOLLY Electric On-Road 451 03-15-2007 09:12 AM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
