Old 06-18-2009, 07:24 PM   #16
AutieBender's Avatar
Wowwwww I have snapped ears off the case, cracked the case along the bottom, Blown a hole in the side of the case and now you put force on the motor and the thing disinegrated. V specs definetly have a case problem. And there front bearing leak. My EB mods v spec came with ceramic special sealed bearings... still leaked. Motor has constant air leaks, runs hot, flames out.
My new novarossi is PERECT! Douglas why dont you just run plus 4 like your dad? Hasnt he been having WAY less problems than when he ran v spec? Also my sirio ran good.
Team Losi/Novarossi/Losi Tires/Nitrotane/JR propo/Upgrade Graphics
Quicks R/C Hobby Shop
Surprise, Arizona
AutieBender is offline   Reply With Quote
Old 06-18-2009, 07:26 PM   #17
Jaz240's Avatar
Trader Rating: 52 (100%+)
your Sirio ran good till you blew it up! When in doubt lean it out, till it grenades!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-18-2009, 07:30 PM   #18
slumlord's Avatar
Don't mean to hi-jack your thread Doug but I have a quick question about my V-Spec as well!
I just had a mild pinch done to the sleeve, I'm doing the break in on it and it seems like when I let off the gas when I'm buzzing around the parking lot it is almost jake braking. It makes this puttering noise like your car would if you had a standard trans and let off the gas while in a low gear.
I have never heard an engine do this before, it seems rather odd. Also forgot to metion it's installed in a Losi 2.0T with a fresh clutch.
Jay Stuart #66
slumlord is offline   Reply With Quote
Old 06-18-2009, 07:43 PM   #19
Jaz240's Avatar
What kind of temps are you at..maybe the piston is sticking in the sleeve?
Is the piston skirt hitting something?
these are obviously just guesses...the only other thing that comes to mind is one of the bearings has a bad ball, which is jerking the shaft around
did you take it apart and check it?
Old 06-18-2009, 08:11 PM   #20
slumlord's Avatar
Temps are 220ish and it stops if I hit the brakes. It only does it if I give it a fair amount of gas and let it coast. But as I said the instant you brake it stops.
My initial guess is it's the front bearing, but it seems to run rather stable and at good temps and has insane power. So at this point it's hard to tell.
Jay Stuart #66
Old 06-18-2009, 08:58 PM   #21
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
GRP engine tooling kit will solve all of your problems. And get one while you still can. GRP will no longer be making engines so I would assume they won't make the tooling kit either. Really saves a LOT of headaches.
As for your issue, you will need a new case. As jpalessi reccomended the ninja case is the best one. Speed and v-spec cases are basically the same(the carb pinch bolt is different). But if you can find a deal on a good condition v-spec case you should be fine. Just DON'T slap the engine on the exhaust port. To remove the bearings with the oven method, you should only hit the engine on the backplate.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-18-2009, 10:35 PM   #22
losi_racer's Avatar
Trader Rating: 25 (100%+)
my dad had zero issues with his vspec. And im breakin the nova in saturday for the buggy cause bill from bce speed chassis chose me to do some testing at the pit with there new chassis. And i need a truggy motor cause when he gets the truggy chassis done im testing that as well
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-18-2009, 11:52 PM   #23
losi_racer's Avatar
i didnt slap the exhaust port, it was the back plate area, and you said the speed case was the same except the pinch bolt, whats different
Old 06-20-2009, 10:32 AM   #24
Autie's Dad's Avatar
My sirio had 6 gallons on it and still had machanical pinch. sometimes I'd have to use the heat gun just to start the thing. But in the main at nitro cross (the o-ring in my hsn was worn out) the highspeed needle screwed itself sll the way in and the motor just blew up. But it did not lean bog.
And after 6 gallons it did not flame out once!!!
Bruce Bender
Cigar Powered Nitro Losi 2.0
One Hobbies
Autie's Dad is offline   Reply With Quote
Old 06-20-2009, 11:30 AM   #25
losi_racer's Avatar
didnt that happen to kenny as well? if the +4 preforms as good as people say ill be stickin with it
Old 06-20-2009, 11:33 AM   #26
The speed pinch bolt is larger for some reason. So if you went to the speed case you would need to get the speed pinch bolt too.
As for hitting it, I really doubt it would just fall off without being dropped/slapped. It is weak metal, but still metal. Unles you had already cracked it earlier, it wouldn't just chip like that without some kind of impact.
-Koby Kubrin-
Old 06-20-2009, 12:03 PM   #27
losi_racer's Avatar
jammin, honestly, i had to put it in the oven for so long i think the case just got brital
Old 06-20-2009, 12:39 PM   #28
I see. Well again GRP bearing tool solves that problem. There are others too, that work very well. The GRP one is very nice and works with most sizes(above 13mm). no heating required!
-Koby Kubrin-
Old 06-20-2009, 01:08 PM   #29
Jaz240's Avatar
Now you need to explain, how the GRP thingy gets the bearings out without expanding the case? The case is what holds the bearings in place
You have my interest. Please go on
Old 06-20-2009, 02:30 PM   #30
i would imagine it's like a gear puller, with a high torque pulling action similar to that of a come along.
Just a guess.
dreaux is offline   Reply With Quote
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
MAX POWER ENGINES Secret_weapon Onroad Nitro Engine Zone 334 08-29-2010 09:54 AM
Practice on a race motor? wick3dr00st3r Nitro Off-Road 24 01-09-2009 03:50 PM
5 cell in 27t/19t MR JOLLY Electric On-Road 451 03-15-2007 09:12 AM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
