Old 06-18-2009, 12:31 PM   #16
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by rcgeezer View Post
You da man JAZ!!
occasionally I even give out the correct answer
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-18-2009, 03:57 PM   #17
jrwoodchuck's Avatar
Originally Posted by Jaz240 View Post
what I find to be impossible is to have every shock the same..you cant possibly know how far you are pushing the shaft into the body (unless she screams.)
Hey Jazzy!
A trick that I use is fuel tubing. First I measure the length of the shaft when the shock is built. Then I take three pieces of the fuel tubing, cut one that is 25% of the length that I measured, then one at 50% and the last one at 75%. I then cut all three down the length of the tubing, that way I can put them over the shaft to adjust my rebound as I'm building the shocks, and they pop right back off when I'm done.
I used green tubing for front and pink for rear. I get them mached every time....
If I want...
75% rebound, use the smallest piece
50% rebound, use the middle
25% rebound, use the biggest one
Saddly I sent those along with my 808 to that "FRIKING LOOSER"!!! And no, still haven't herd anything.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 06-18-2009, 04:03 PM   #18
Frank L's Avatar
Trader Rating: 148 (100%+)
I like to build my shocks with very little rebound and then use the oil/ spring/ piston for tuning. I would say using the method described above I build them with somewhere between 10 and 20% rebound. Works for me.
Old 06-18-2009, 07:43 PM   #19
Akhor's Avatar
Originally Posted by jrwoodchuck View Post
Hey Jazzy!
A trick that I use is fuel tubbing. First I measure the length of the shaft when the shock is built. Then I take three pieces of the fuel tubbing, cut one that is 25% of the length that I measured, then one at 50% and the last one at 75%. I then cut all three down the length of the tubbing, that way I can put them over the shaft to adjust my rebound as I'm building the shocks, and they pop right back off when I'm done.
I used green tubbing for front and pink for rear. I get them mached every time....
If I want...
Wow, this is a great idea!
I always try and eyeball and it's impossible. I'm going to do this next time forsure!
Thanks!
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 06-18-2009, 07:46 PM   #20
Jaz240's Avatar
Thanks!
I agree, think I'll skip the "PINK" tubing though
Old 06-18-2009, 07:57 PM   #21
Just to be a jerk, I have fioroni(never can spell that) rebound pistons in my mugen.They rebound faster than they compress or have less resistence coming out than going in if that sounds better. That is what cary(not the O.P.) was refering to I would think, & yes,you can feel the difference.But no they are not adjustable unless you consider piston replacement as adjustable.
butch man is offline   Reply With Quote
Old 06-18-2009, 08:04 PM   #22
I tried blue, but i got them mixed in with junk tubing lying around. So i went with loud colors.
Doug
TLR 22/M-11
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 11:12 AM
Adelaide Nitro Offroad Racing Club oblivion Australian Racing 19736 01-14-2017 01:12 AM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 09:03 AM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
