Old 06-17-2009, 07:28 PM   #1
HomeKrew's Avatar
Default Help me spend my money!
Hey, I am completely new to the RC Car world and I am purchasing a Team Losi 8ight-T 2.0 RTR. So, other than the (2)7.2v/3600mAh battery packs, a Glow Starter and of course Fuel, what are the kind of things that I should really have on hand for a future of running and working on these things? What things are a "Must Have" and what things are "Nice to Have's"?
I currently fly RC Helicopters and have all of the tools, chargers, and equipment to run those, but I am unsure how much of what I already have will work on RC Cars too. If I am going to get into a new hobby I want to do it right and make sure I am prepared.
Any help you guys can give me on how to spend my money would be greatly appreciated.
HomeKrew--------------->
HomeKrew is offline   Reply With Quote
Old 06-17-2009, 07:55 PM   #2
pballer2777's Avatar
Trader Rating: 27 (100%+)
r u goin to race? if so u may want to get some spare parts in case of breakage. even though have run nothing but losi i have never broke anything. but i do have all parts just in case. i could go on forever what i bring to the track. so it all depends on what ur plans r.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 06-17-2009, 08:07 PM   #3
Trader Rating: 125 (100%+)
You could spend some money on a plane ticket to hawaii and enter our race here. jk
on the Losi, I would get some extra shock ends. I had 3 out of the 4 pull out on mine on the first tank of fuel. One even popped off taking it out of the box. This was on the race roller though. Maybe they updated them on the RTR. Also if you are planning to race then maybe a higher torque servo for the steering. Most of us here use the Hitec 7955TG, thing is an animal. Its got some decent servos though. Other than that I think the RTR is all good, even got some better parts than the race roller! Losi did a good job putting that package together. good luck
----Answer RC-USA----Stickit1 Racing----PT Racing Hawaii----808-RC----702 Raceway-----Dialed RC-----
Neesh is offline   Reply With Quote
Old 06-17-2009, 08:12 PM   #4
i also use the hitec 7955. what u could do is put the stock steering servo as the t/b and get the hitec for steering.
Old 06-17-2009, 08:16 PM   #5
mudboger07's Avatar
i just purchaced the 2.0 rtr buggy for my son, the first thing we replaced even before running it was the servos, get any high torque srvo that you like, upgrade the steering servo horn to alum, tires get plenty....lol the track will change threw out the day....like said above the list can go on but id at least start with the above.....oh and a GOOD temp gun....hope some of this helps.......
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 06-17-2009, 08:16 PM   #6
camocowboy's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to camocowboy
Default Parts
Aluminum front spindles, adjustable hinge pin braces, and maybe smart diffs. All are nice to haves but make a difference in performance. For track tools you should get a digital caliper and a ride hieght gage plus all wrenches for the car. Losi uses standard mostly.
#92 Greg Singletary
Punched R/C Productions - Ascendancy Racing - Byrons Fuel - JGO Paint - The Nitro Pit - One Hobbies Shop and INDOOR RACEWAY
camocowboy is offline   Reply With Quote
Old 06-17-2009, 08:23 PM   #7
Focusprinting's Avatar
Must Haves:
Get a really good steering servo, spare parts, spare glow plugs, an AMB transponder (if you plan to race), a glow plug wrench, a couple of sets of tires (see what people are running at the track), diff oil (check the losi threads for recomendation), shock oils (check losi threads), a good set of hex wrenches (if you don't already have them), clutch shoes and springs (the RTR only comes with 2 clutch shoes but the losi clutch will accept 4), and air filter oil.
Nice To Haves:
Nice gloves (for turn marshaling), simple green (gotta keep it clean), engine sealant (I hear the Lucky 7 stuff is really good), pro kit upgrades (not needed but it would be nice), a custom painted body (gotta stand out at the track ) a Nova 21-4 engine (hey, this is the nice to have section), and the winning lotto numbers
www.focusprinting.com
Focusprinting is offline   Reply With Quote
Old 06-17-2009, 08:44 PM   #8
vladconnery's Avatar
Trader Rating: 35 (100%+)
Must have for losi rtr
aluminum servo saver
aluminum steering servo horn
upgrade steering servo (keep steering servo for spare for throttle only)
extra glow plugs
tires (the most important part of set up)
a transponder (not necessary but really nice if you don't mind putting out $100)
ride height gauge
camber gauge
set up sheet (use it)
after those upgrades race it, learn it rinse repeat. By the time you compete in an entire point series which is a good idea. You will have met enough people been in the pit enough. Seen plenty of good and bad engines. Good and bad cars. To know what else you want. Practice does not prepare you for racing like racing does.
Don't waste your money buying a bunch of stuff you probally want need. You can by all the spare parts you want. However you always end up breaking something you don't have.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 06-17-2009, 08:52 PM   #9
busaboy's Avatar
must haves:
tires
spare wheel bearings
spare clutch bearings(absolutely must have)
spare diff bearings
glow plugs
shock oils
diff oils
after run oil
lock-tite
grease
ready to use air filters(very important to keep clean spares as they get dirty in a hurry)
body clips
quality wrenches
fuel bottle
nice to haves:
spare parts....control arms, outer hinge pins, front tko crank bearing (dual rubber shielded), servos, clutch shoes, clutch springs, shock caps, rod ends, etc.
sleeve puller kit (offna and grp makes them)
im sure there are more goodies
busaboy is offline   Reply With Quote
Old 06-17-2009, 09:03 PM   #10
extra glow plugs
ride height gauge
camber gauge
Originally Posted by busaboy View Post
must haves:
tires
spare diff bearings
glow plugs
shock oils
diff oils
after run oil
lock-tite
grease
body clips
quality wrenches
fuel bottle
nice to haves:
+1 on that. I remember changing out my wheel bearings early too. My friend Buggymaster recommended that and got me some Avid bearings. Stock ones wore really quick.
Old 06-17-2009, 09:48 PM   #11
Frank L's Avatar
Trader Rating: 148 (100%+)
I have had this truck since it first came out. I installed the following on my 2.0. Fioroni top alum plate, fioroni inner hinge pin braces, fioroni shock caps, (I tried fioroni adj outter hinge pin braces and they lost the inserts eventually) king headz putter hinge pin braces, alum front spindles, modded rear hubs or king headz ( the outter bearings are too small and blow up fast) alum servo saver top losi or king headz, lightened diff out drives, smart diffs f/r, king headz 6061 alum clutch shoes, hitec 7955 steering servo, hitec 7985 throttle. Leave the f/r plastic braces in and get some spares because they will break, but they allow the chassis to flex like it's suppose to. I also picked some trick carbon fiber shock towers (unnecessary but they look cool) You need tires aka cityblocks and I beams will cover most track surfaces. As for spare parts an ample supply of bearings losi makes a kit, shock ends they may come stripped out from losi, a spare gas tank, some fuel tubing (I like the kyosho tubing), extra glow plugs, losi makes a screw kit that is nice to have and I think that about covers it. I know some will think this is over the top and completly unnecessary, but I like to add all the options just the way I am. I would also throw a new body and an upgrade wrap on it too. If that's too much all I can say is you asked.
Old 06-17-2009, 11:12 PM   #12
HomeKrew's Avatar
Very Cool!
I do plan on racing at some point, but not right away. I want to take some time to practice and learn how to basically tear the thing apart and put it back together. I want to learn it inside and out.
So it looks like I still have a lot of things to buy, but I think I have all the tools required from my RC Heli and I already have: Digital Calipers, AfterRun Oil, Temp Gun, Glow Plug Wrench, Hex Wrenches, Loc Tite, and Grease .
I created 3 lists below... Things I 'Must Have' on hand that are used every day or that need to be upgraded right away. Things that are 'Good To Have' on hand if something breaks or is needed but certainly not an everyday thing. And lastly 'Nice to Have' things for upgrades and those things that improve performance or just give it more BLING.
Let me know what you think of the lists and if I am still missing something or if something is in the wrong list.
Must Have:
Tires
7955TG Servo Upgrades
Aluminum Servo Horns
Aluminum Servo Saver?
Shock Caps
Rod Ends
Ride Height Gauge
Glow Plugs
Differential Oil
Shock Oil
Clutch Shoes and Springs
Air Filter Oil
Camber Gauge
Set Up Sheet
Wheel Bearings
Clutch Bearings
Differential Bearings
Air Filters
Body Clips
Fuel Bottle
Good To Have:
Aluminum Front Spindles
Adjustable Hinge Pin Braces
Smart Differentials
AMB Transponder
Control Arms
Outer Hinge Pins
Front Crank Bearing
Sleeve Puller Kit
F/R Braces
Gas Tank
Fuel Tubing
Screw Kit
Nice To Have (or Wish I Had):
Gloves
Simple Green
Engine Sealant
Pro Kit Upgrades
Custom Painted Body
Engine Upgrade
Performance Upgrades
MORE BLING!!!!!
Oh... Ticket to Hawaii and Winning Lotto Numbers
Old 06-18-2009, 01:14 AM   #13
shock ends
Old 06-18-2009, 04:10 AM   #14
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
3600 mAh battery packs? You're just powering a receiver, transponder, and servos. My pack (and I only have one!) is only 1600 mAh and easily lasts a 45 minute main. I'm pretty sure you could save some $$ there to spend on other upgrades.
Keep in mind that the Losi is SAE not metric... so if your heli equipment is metric you'll need hex wrenches at the least.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-18-2009, 04:54 AM   #15
I'm pretty sure the 3600 packs are to power the starter box that comes with the RTR. not the receiver. And if you plan to buy shock caps, buy the kit shock caps because they are aluminum, but not totally necessary.
Jeremys8T is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
LRP SPHERE COMP. ESC (80700) Miu Miu Electric On-Road 725 07-08-2010 03:42 PM
STABILITY savage vs. revo super jato dude Monster Trucks 25 05-23-2007 08:33 AM
AMB Personal Transponders...Too Expensive? Fred Perkins Electric On-Road 240 01-05-2006 07:18 PM
Integy cheap tire truers? Tire truer help! 24601 Electric On-Road 38 07-13-2004 05:48 PM
Becoming a retailer B3boy Chat Lounge 12 04-28-2003 12:57 PM
