Old 06-17-2009, 06:31 PM   #1
omarwashington's Avatar
Default Engine bearing replacement question
Is it possible to only change the front engine bearing using the oven treatment method?
I’m pretty sure the rear bearing on the engine is still good.
RCCARS!
omarwashington is offline   Reply With Quote
Old 06-17-2009, 06:39 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Yes when you heat it up to put the new front bearing in, just re-insert the old rear one..Kinda silly though, spend the extra $20 and replace both Omar..dont take the chance. Usually both TKO's are $35 for most engines
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-17-2009, 06:44 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1
Even if you "think" the rear bearing is good, it is worth changing it to a ceramic.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-17-2009, 07:05 PM   #4
ya
i have new front and rear bearings, the rear one thats in there is ceramic and the new rear bearing is also ceramic. I just thought I'd save a few$$ by just replacing the front bearings.
RCCARS!
Old 06-17-2009, 07:30 PM   #5
Jaz240's Avatar
If you are sure the rear bearing is good then just change the front. the heat wont hurt it..just stay under 300 degrees
Old 06-17-2009, 10:16 PM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
If you heat that engne up in the ovenxhances are that rear bearing will more than likely fall right out. GRP engine tool is all I need to say. If the rear bearing is good then yes just replace the front.
Old 06-18-2009, 12:06 AM   #7
Jaz240's Avatar
you will have to remove the rear bearing in order to get the front one out Frank, so even if it dont fall right out, He would still need to remove it, before he can swap out the front one. the front bearing will not fit through the hole in the rear bearing
Old 06-18-2009, 02:21 AM   #8
losi_racer's Avatar
Trader Rating: 25 (100%+)
what are you talkin about james? you put the front bearing in thru the front, not thru the rear hole.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-18-2009, 02:41 AM   #9
Frank L's Avatar
I have used heat to remove the bearings several times and taken the font out without removing the rear. Am I missing something??
Old 06-18-2009, 08:52 AM   #10
Jaz240's Avatar
I"ve only had to do it twice, and both times after I heated I tapped the whole case on the counter and both bearings fell out the back.. I never realized you could take the front out only with a heat gun through the front...I learned something today..That's why I love this site! Thanks guys
Old 10-09-2009, 12:32 AM   #11
dlb
Is it a bad idea to put some afterrun oil to help the new bearing to fall in place?
dlb is offline   Reply With Quote
Old 10-09-2009, 12:50 AM   #12
Suspended
That's impossible, you must be joking !.
The front bearing has a O.D. of 19mm,whereas the hole of the cranckcase for the crankshaft to go through from the rear bearing to the front bearing is only 15mm. Therefore, the front bearing can only fall out to the front.
Chicks all SOLD OUT !!
Owner retired happily, now looking 4 chicks instead liao !
TonyNg is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
c6,os speed,go modded Ultraspeed84 Nitro Off-Road 59 08-18-2007 08:04 PM
New car in need of an engine Demigawd Nitro On-Road 18 03-19-2004 03:48 AM
