Old 06-17-2009, 02:56 PM   #1
Default O.S Vspec 2007 production year
Hi guys i am about to buy a new in box vspec produced in 2007. Any problems i should be aware about because i heard there was a bad batch in some? Thanks for the help.
roots is offline   Reply With Quote
Old 06-17-2009, 03:56 PM   #2
Trader Rating: 26 (100%+)
No problem with them.The first VZB's that came out had some problems but all the V-SPECS are fine.
bphil49 is offline   Reply With Quote
Old 06-17-2009, 04:19 PM   #3
Carb might be different and I think it will have the V-Spec carb boot on it. Maybe have the old case (sticks out by the backplate) too. Mine came with the speed boot, new carb and new case.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 06-17-2009, 04:28 PM   #4
PTP Racing's Avatar
I think the 07 version is the newer case and bearing. Check the bottom of the case. If the 2 humps where the bottom back plate screws go in go up more than 3/8 inch that is the newer case and the big change for 07. Later on they changed the carb.
The older cases were more prone to cracking and the bearings in all V-Specs have a pretty high failure rate. If the case cracks your going to know because the tune will go nuts and the chassis will get fuel all over. The bearing will last a while listen to it and when it starts making noise replace it.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 06-17-2009, 05:05 PM   #5
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1
The 07 model has the new case, but not the new carb. The 08 model was when they introduced the 21j carb over the 21c carb. The old carbs are fine, but the blue boots tear easily. The idle screw is also harder to access when in the buggy position. You should be good to go. I still reccomend changing bearings and rod after break in to the 3 gallon mark. TKO ceramics and a speed/ninja rod is what I would do.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-17-2009, 06:02 PM   #6
Thanks for the help guys. This thing must have been sitting for a few years but it is still new in package and oily so it should be good to go. Got it and the os speed tuned 2060 complete set and Super air cleaner all brand new in package for 250 Canadian. Hope i got a good deal.
Old 06-17-2009, 07:39 PM   #7
Jaz240's Avatar
Trader Rating: 52 (100%+)
Thats an awesome deal..Thats like $150 USD..good for you
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-17-2009, 10:09 PM   #8
Let me get this straight. If there is 2 humps by the bottom back plate scr ews it is the newer or older version? Mine has no humps....
