Old 06-16-2009, 11:30 PM   #1
cluffy1's Avatar
Angry HELP!!!!!
is there anyway to bend a chasis back into shape. i have landed a jump very badly and landed right in the middle of the chasis. and bent it. it is a 3-5mm off of a flat surface.
thanks
cluffy1 is offline   Reply With Quote
Old 06-17-2009, 01:41 AM   #2
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
thanks
remove everything and hammer it
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 06-17-2009, 02:44 AM   #3
I honestly think that even if you got it straight again, the chassis has been weakend and it will bend easily if exposed to similar forces. What kind of vehilce is it for? I would also try and check ebay to see if people are parting out kits so that you can save some money that way. Good luck.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 06-17-2009, 11:18 AM   #4
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
Agreed. I tried to fix a bent D8 chassis in a 12-ton press but no matter how far I deflected it it would spring back. A 3-lb sledge hammer and some wood blocks to protect the chassis finally did the trick.
I did pick up another new chassis for cheap and decided to save the straightened one as a spare. You never know if it'll handle quite right after being tweaked.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 06-17-2009, 12:10 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
trash it! a Bent chassis will destroy your drivetrane, as well as clutch bell, spur gear, bearings,chassis braces, front and rear towers..It's just not worth it
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-17-2009, 12:12 PM   #6
I know how to fix it - it will only cost about $100
j/k
you need a new one bud
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-17-2009, 06:30 PM   #7
cluffy1's Avatar
i have rebuild my the car and placed everything back on the car. i have pushed it along the ground and nothing seems to be hiting or touching (thant shouldn't). is it still good.
Old 06-17-2009, 06:45 PM   #8
slumlord's Avatar
I wouldn't trust it but that's just me, I'd spend a few bucks and get a new one.
Jay Stuart #66
slumlord is offline   Reply With Quote
Old 06-17-2009, 06:47 PM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
I had a LHS owner tell me to never tell he did this but he took the car, griped it at the front and rear and bent it over his knee till it was straight. It's not perfect and it takes a lot of force but it will help. The best way is just trash the chassis and upgrade it to BCE, matrix, or something like that.
