Old 06-16-2009, 07:12 PM   #1
Akhor's Avatar
Default Graphite Grease vs Green Slime
Recently there has been some talk about using graphite grease on drive pins to extend their life.
I'm wondering if you could not just use graphite grease through out the vehicle instead of using green slime. Or is there specific places that the green slime would be better?
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 06-16-2009, 07:21 PM   #2
omarwashington's Avatar
I use the green stuff on all rubber o rings
RCCARS!
omarwashington is offline   Reply With Quote
Old 06-16-2009, 08:07 PM   #3
Akhor's Avatar
True, I suppose green slime is better on rubber.
--Blaine--
VBC D07, VBC D08
Old 06-16-2009, 08:08 PM   #4
Akhor's Avatar
Also, when you are applying the graphite grease to the drive pins, is it worth putting it on the outdrives as well?
--Blaine--
VBC D07, VBC D08
Old 06-16-2009, 09:19 PM   #5
I apply green slime to all shock o-rings. black grease to all differential o-rings, and graphite grease around the CVD coupling. I do not see a benefit to applying it to the drive pin itself and would avoid graphite grease elsewhere as you would want something thicker to properly seal both diffs and shocks.
-Kane
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 06-16-2009, 11:46 PM   #6
WheelNut's Avatar
Send a message via MSN to WheelNut
Green slime is specifically designed to be used on O-rings. It reduced stiction and improves seal quality. Dry graphite lube or O'donnell wax lube is good for use on exposed parts because it won't allow dirt to stick.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 06-17-2009, 06:10 AM   #7
Akhor's Avatar
What about on the ring and pinion? Can you use it there instead of black grease?
--Blaine--
VBC D07, VBC D08
Old 06-17-2009, 06:21 AM   #8
slaytanic's Avatar
Trader Rating: 20 (95%+)
Green slime is NOT meant for any metal to metal lubrication.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
