Old 06-16-2009, 03:59 AM   #1
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Tko Engine bearings vs Oem Novarossi bearings
Seems to be a huge price difference between the tko ceramic aftermarket bearings and novarossi steel bearings and ceramic bearings.
Does anyone have any hands on experience with quality vs price of bearings.
I like to keep my practice motors fresh and factory bearings are so expensive it is nearly cheaper just to replace the entire engine!
Jamie
J.Gonzalez is offline   Reply With Quote
Old 06-16-2009, 06:59 AM   #2
Trader Rating: 24 (100%+)
I am assuming you are talking about TKO ceramice being much cheaper than the stock bearings. Don't let that sway you away. TKO bearings are high quality and used by many of the USA's top drivers.
I personally use them for engines we work on at The Speed Shop, and have always had great results.
hope th at helps!
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 06-16-2009, 07:09 AM   #3
cary's Avatar
Trader Rating: 67 (100%+)
have put TKO bearings in all my v-specs they are top notch
now have them in my clutch they are a good bearing
got my last set from Joe at LUCKY 7 at a good price
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 06-16-2009, 07:48 AM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
TKO's are VERY high quality bearings at frankly a very cheap price. I use them in all of my engines with great success. TKO's are the ones that are priced correctly. Not sure why anyone would pay double for a stock steel bearing. Pretty stupid if you ask me. Another +1 for TKO.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-16-2009, 11:34 AM   #5
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Well, you are paying for one very important factor with the factory bearings. It costs them a lot to print the labels for the package that say Novarossi on them.
Get the TKO bearings, you won't be sorry.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-16-2009, 11:46 PM   #6
sickboy's Avatar
Trader Rating: 72 (100%+)
I have had so many issues with NR stock bearing that I now switch to TKO after initial break-in. NR=the best motors with the worst bearings.
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 06-17-2009, 12:18 AM   #7
losi_racer's Avatar
Trader Rating: 25 (100%+)
tko bearings are good, i did just have one fail at the gallon mark on my vspec but its the first out of like 5 sets ive done
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-17-2009, 12:21 AM   #8
dishsoap's Avatar
This may or may not be a new line however I just read in a magazine that TKO has bearings that are made for a higher RPM than most manufactures.
I dont have experience but everyone raves about TKO.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 06-17-2009, 01:23 AM   #9
houston's Avatar
Trader Rating: 91 (100%+)
they are the best engine bearings at the best price
they work very well and i use them in almost all my engines , one size needs a little work
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-17-2009, 07:41 PM   #10
Trader Rating: 49 (100%+)
Where is the best place to get TKO bearings? I'm getting a V-spec and I want to put a pair in. Also, what's the best way to get the center bearing out? I know baking the case, but then how do you pull it out?
-Mike B. - TLR22 - Tekin - K.O propo
aradaiel is offline   Reply With Quote
Old 06-17-2009, 08:52 PM   #11
Here ya go!
http://carolinasrc.com/Webstore/Scri...idproduct=1385
http://carolinasrc.com/Webstore/Scri...idproduct=1384
Once you get the case up to temp, slap the back of the engine(where the backplate goes) on a piece of wood or a counter top. Bearing should pop out with a couple of solid taps
I agree! And know what size you are talking about.
-Koby Kubrin-
Old 06-17-2009, 08:59 PM   #12
busaboy's Avatar
mark puts tko's in his race engines. and he put them in mine. so far so good. my NR front is leaking at 1.5 gallons.... oh well one call to mark at powerhouse performance and he hooked me up with a new tko.
good luck
busaboy is offline   Reply With Quote
Old 06-17-2009, 09:01 PM   #13
sickboy's Avatar
Buy them direct from TKO....... http://tkocompetitiondev.com/
Old 06-18-2009, 04:22 AM   #14
DOMIT's Avatar
Get a bearing puller. The OFNA one works pretty good...
http://www.amainhobbies.com/product_...oducts_id/3528
Old 06-18-2009, 04:34 AM   #15
Davidka's Avatar
Trader Rating: 75 (100%+)
Uh, why don't you be a pal and tell everyone what size so they don't buy it, hate it, and later come on these forums and trash TKO's good name?
