Old 06-15-2009, 11:30 PM   #1
Tree's Avatar
Send a message via ICQ to Tree
Default Help with Big Bore Shocks
I have a set of Hobao 17mm shocks that I put on my Truggy. The problem I am having is when I push the car down to compress the shocks, the car doesn't return to normal ride height. The rig stays down a centimeter or two above the ground. I have tried adding more fluid to the shocks, and putting less fluid, I have tried both compressing the shock shaft when screwing on the shock cap and also leaving the shaft fully extended. I even tried different weights of shock oil. Nothing seems to fix this problem. Any help from anyone will be greatly appreciated.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 06-15-2009, 11:40 PM   #2
Did you try more pre load?
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 06-16-2009, 12:10 AM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
yeah the springs control the ride height, not the oil
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 06-16-2009, 06:19 AM   #4
slaytanic's Avatar
Trader Rating: 20 (95%+)
You may also have a bind somewhere. If your hingepins are dirty and binding a bit it will do just what you are describing. You can combat this somewhat with preload.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 06-16-2009, 08:15 AM   #5
Tree's Avatar
I appreciate the replys. I had the pre-load adjustment ring set down as far as it can go. My truggy still won't return to normal ride height. When I push it down, my truggy rebounds and the chassis stays barely a centimeter or two above the ground.
I don't think it is my hinge pins but I will double check those to make sure they are clean and not bent.
Team Holy Rollers
HiTec Servos
Old 06-16-2009, 08:50 PM   #6
Tree's Avatar
I got it all worked out guys. I appreciate the suggestions. Thanks again.
Team Holy Rollers
HiTec Servos
Old 06-16-2009, 08:55 PM   #7
Gixxer2k4's Avatar
Send a message via AIM to Gixxer2k4
what did it end up being?
Mini 8ight
Gixxer2k4 is offline   Reply With Quote
Old 06-17-2009, 09:06 AM   #8
Tree's Avatar
the shock springs were about a turn too short in the rear and about a half a turn in the front. I put a set of grey Jammin 16mm springs on the shock bodies and that seemed to do the trick. It works great. Now when I push my truggy down, the shocks rebound and my rig comes back to the ride height I set. I'm looking forward to getting my rig out to a track to see how it handles.
Team Holy Rollers
HiTec Servos
Newbies Queries - Ask and you shall be answered! renben Singapore R/C Racers 4617 07-21-2017 11:28 PM
TQ Racing SX8 vino1 Nitro Off-Road 3254 11-15-2012 02:53 PM
Jammin X1 - so close yet so far beetlebz Nitro Off-Road 4524 03-25-2012 01:54 PM
My Kyosho SP2 with Mugen MBX6 Big Bore shocks. *Chrominator* Nitro Off-Road 11 01-23-2009 09:35 AM
RC8 Factory Team vs MBX 6 need some feedback robbdny Nitro Off-Road 79 12-14-2008 10:37 AM
GS CL-1 x2 *fioroni hopped up,RB S7lll,Collari B7,Starter Box etc. GSCL-1 R/C Items: For Sale/Trade 10 10-22-2007 06:56 AM
