Old 06-15-2009, 03:31 PM   #1
CaptCrunch's Avatar
Trader Rating: 17 (100%+)
Default Torsen center diff
Hey folks, are any of you running a Torsen diff? I picked one up in a trade, and I need to know what exactly I do to lubricate it. It goes together differently than a regular diff with a metal sleeve that slides over the gear housing and only seals by a couple of o-rings. Am I supposed to fill it with diff fluid? Oil?
I've never worked with one of these before. It's silky smooth, but MAN is it a pain to disassemble. I had to tear it completely down to change bearings.
Never met an RC I couldn't crunch! If it never breaks, you're not playing hard enough.
Current Toys: 1990 RC10 Gold Pan buggy, 1991 RC10 Team Buggy, AE TC3, Diggity Designs XLR8, Tamiya TRF 415, Losi Mini Late Model, Losi Mini Slider, AE RC18MT, 2 Jammin X1X CR's, 2 Jammin X1 CRT Pro's, HPI Savage XL, Revo Platinum, Jammin X2 CR Electric Conversion, 4X2 Slash, 4X4 Slash, Losi Comp Crawler, Arrow Shark 47" Boat, Blade 400 Heli, Blade CX3
CaptCrunch is offline   Reply With Quote
Old 06-15-2009, 08:08 PM   #2
CaptCrunch's Avatar
Nobody here has ever used one of these?
Old 06-15-2009, 11:20 PM   #3
garen's Avatar
Which brand/what model torsen diff do you have?
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 06-16-2009, 07:50 AM   #4
CaptCrunch's Avatar
It's the Ofna Torsen that woks with the Jammin buggies.
Old 06-16-2009, 09:13 AM   #5
garen's Avatar
Have you tried contacting OFNA tech support?
Old 06-16-2009, 09:34 AM   #6
vladconnery's Avatar
Trader Rating: 35 (100%+)
Torsen and smart diffs use grease not oil. the losi diff grease should work fine in it. I would make sure that the grease fills the entire diff. Just greasing the parts usually does not work as with centrifugal force. It will sling the grease to the outside of the diff housing neglecting the gears. I fill my smart diffs up and check them after a gallon they were fine. There was noticeably less grease in the diff but more than enough to keep it well lubricated. However as with the previous poster I would check with OFNA.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 06-16-2009, 10:13 AM   #7
garen's Avatar
The old Fioroni Hyper Traction torsen diffs used oil instead of grease. The OFNA diff he has might be one of the older models which if memory serves me correct, looked a lot like the Hyper Traction diffs. Otherwise most if not all of the more recent torsen diffs use grease. The type of grease varies though, so even if the OFNA diff uses grease, there might be a specific grease recommended by OFNA.
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Assorted Items, RC8 Body, 1/8 Tires, Batteries, Fironi Torsen Diffs, ect "Smiley" R/C Items: For Sale/Trade 41 03-13-2009 07:46 PM
Diffs and you - a discussion about the magic world of diff technology Rysuleod Electric Off-Road 13 09-07-2006 06:36 PM
Help with diffs bigblockbuggy Electric Off-Road 11 12-11-2005 11:27 PM
