Old 06-14-2009, 04:14 PM   #1
coviello's Avatar
Default keep frying servos
hello. i have the futaba 3pm 2.4ghz radio. i am using futaba digital coreless servos. last week i ran all day with the new servo. right at the end. it fried. today i bought a new servo. futaba digital coreless. and again. fried it right after the 15 minute a-main. does anyone know whats going on? thanks for any help!!
coviello is offline   Reply With Quote
Old 06-14-2009, 04:21 PM   #2
Frozenshades's Avatar
Are you properly setting the EPA? If you don't set the end points the servo will try to turn the wheels (or move the throttle) further than it is physically able to go. That causes a lot of strain on a servo motor and it breaks pretty quick.
Frozenshades is offline   Reply With Quote
Old 06-14-2009, 04:27 PM   #3
coviello's Avatar
ok. ill try that once the new one comes
Old 06-14-2009, 04:38 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Try it? As in you werent setting the EPA before??? If that's the case, I'm surprised the servos are lasting 2 minutes, let alone 15. EPA and linkage setup is the biggest reason for servo failure.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-14-2009, 05:22 PM   #5
I usually reduce the servo EPA to way less than full throw on steering both left and right, then turn the wheel on the transmitter all the way and increase the EPA right until the wheels hit maximum throw. Then bring them back a few degrees from max. Seems to work for me.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 06-14-2009, 06:31 PM   #6
also dont know if any of you have used them but the hyperion digital servos rock. I have them in my revo and love it.
Revo 3.3
Losi 8ight
Stampedes xl5
rage326 is offline   Reply With Quote
Old 06-14-2009, 07:54 PM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
I recently had a problem in my 8T 2.0 blowing the throttle servo over and over. One race day I lost 2 in the same day. The epa was good but the servo was hitting the lip on the mud guard causing it to slam and eventually go out. I shaved the mud guard and so far a practice day and a race day on it with out any problems. Check to make sure that the servo case has plenty of clearance as these chassis do flex. Also make sure the throttle linkage is not binding. You should be able to move the card all the way open with the servo not moving by pulling on the end of it. If the action does not feel smooth then adjust where the ball cup is so that the arm is level and works smoothly.
Old 06-14-2009, 08:14 PM   #8
Agreed. That's what I've done and I've never had any major servo problems. The maximum angle on my steering is actually an EPA that exceeds what my radio considers 100%. Seems odd, but it works.
Race Results! Exterminator Northwest Racers 4712 07-09-2017 04:58 PM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
Damn @#$! Radio piece of crap! Samma3l Australian Racing 26 03-27-2003 05:06 AM
