Old 06-14-2009, 03:02 PM   #1
DiaRh34's Avatar
Send a message via AIM to DiaRh34
Default simple question, i think
My buggy drives around fine but when I go to open the throttle all the way it will die.I'm still getting used to getting the needles sit right and I think thats probably what it is.Whats should I do with the needles to fix this?
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 06-14-2009, 03:03 PM   #2
Does this happen all the tme or at a certain point?
Ie. from standing still, at speed, etc.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 06-14-2009, 03:04 PM   #3
DiaRh34's Avatar
while its moving
Taco
Old 06-14-2009, 03:04 PM   #4
shesha's Avatar
Send a message via MSN to shesha
at the top of this forum you will see a thread called the tuning bible it will get you in the right direction
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 06-14-2009, 03:06 PM   #5
buggydad's Avatar
IF it bogs with alot of smoke and gargles lean it out 1 hr at a time.If it bogs with no smoke its a lean bog richen it
buggydad is offline   Reply With Quote
Old 06-14-2009, 05:41 PM   #6
scwrod's Avatar
If you are not sure I would richen the top 4-5 hours. See if the problems goes away. If it does then just take your time and go through the tuning bible.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 06-14-2009, 06:48 PM   #7
hardhead's Avatar
Trader Rating: 97 (99%+)
Lean that baby out!!
XX Fly Low XX
hardhead is offline   Reply With Quote
Old 06-14-2009, 07:00 PM   #8
I have gone through this scenario several times. In the begining i was trying to tune my lsn and hsn at the same time. Big mistake. Leave your lsn flush and tune your high first. And just about every time it was to lean. But if you get a gurgerly bog then it is to rich. If it just cuts out it is to lean. It was just about always the latter. Richen it up, or if your tune gets really screwed. Go to a leaner factory setting, get it idling, get it up to temp, tune the hsn a hour at a time. then once you can go wot (get a wide open area) in a straight line in the fastest time, with a good trail of smoke and temps around 220. when that happens you can tune your lsn. try to keep it on the rich side. to lean and it will overheat or flame out.
dreaux is offline   Reply With Quote
Old 06-14-2009, 07:02 PM   #9
I agree with this too. richen it up, and if that does not solve it, go the other way (lean it)
LST2 BrettL Monster Trucks 472 03-20-2012 10:30 AM
UK Race Talk TryHard Racing Forum 9876 12-05-2010 10:46 AM
Project Team Kassanova TR3 V2 (Tc3 Truggy) eds24 Electric Off-Road 28 06-28-2009 09:20 AM
drivers ethics while racing.... moy Nitro On-Road 72 06-26-2008 03:22 PM
Trinity DPD VS. Teamwave Lightning discharge Equalizing System Jochim_18 Electric On-Road 58 07-25-2007 06:54 AM
BL motors : Why wye? rough512 Electric On-Road 62 04-16-2007 12:40 PM
Most Complete Touring Car??? DEACON Electric On-Road 90 11-27-2002 05:27 AM
