Old 06-12-2009, 10:50 PM   #1
Gen
Gen's Avatar
Default removeing shims ??
is it smart or silly to remove a shim ,on todays hi powered engines to get a bit more grunt ,running a 21 cobra axe rossi and wanted a bit more push for my truggy can i remove a shim for easy fix or no ??
Kyosho MP9 tki3
Kyosho Strr Evo
Os engines
Vp race fuel
Futaba 4pks
Gen is offline   Reply With Quote
Old 06-12-2009, 11:17 PM   #2
what_stanger?'s Avatar
Send a message via AIM to what_stanger?
I'm guessing it would be like advancing the timing on your car without running higher octane. (detonation/pre-ignition)
I'm not positive, so i'd wait for further comments from other guys.
what_stanger? is offline   Reply With Quote
Old 06-13-2009, 07:53 AM   #3
Ive always been told to use the proper shimming for the type of fuel you are running so this would go against the grain. I dont know the complete principal for this but it has to do with detination of the fuel. It sounds good but Im gonna stick with what the engine builders say.
.60 = 20 % fuel
.70 = 25 % fuel
.80 = 30 % fuel
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 06-13-2009, 07:55 AM   #4
Your pipe combo should fix the problem.
Old 06-13-2009, 08:27 AM   #5
Trader Rating: 32 (100%+)
on my OS speed, removing shim gave more bottom, but lost some top end rpm
and ran hotter.
when tuned right, overall power was same
devilchrist is offline   Reply With Quote
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 09:34 PM
Manual Com Lathe or Auto kang45 Rookie Zone 7 01-24-2006 09:32 AM
