Old 06-12-2009, 05:32 AM   #1
Default Rookie w/ nitro rc and hobby store advice?
I recently purchased a Traxxas Rustler with .25 engine for my son. I have zero experience with the nitro RC's and have been trying to do my homework on it. Apparently you are supposed to use some after run oil after using. I went to a local hobby store to buy the 20% fuel and asked for after run oil. He gave me some lightening lub road power and said to use 4 drops of this with a certain amount of the fuel (cant remember the amount 1qt maybe) and that I wouldnt have to use the after run oil. Good advice? bad advice? and if so, do you think Im right on 4 drops per 1qt ratio? thanks in advance
chays33 is offline   Reply With Quote
Old 06-12-2009, 06:17 AM   #2
I would not - Hobbico makes an afterrun oil, I would not put nothing into my fuel, as of fear that it would make it inconsistant Plus one of my local PROS said that wtih some fuels stating that you do not use afterrun oils but they would still use them.
You don't need to use ARO after ever run, but if you not going to run it for a while then its a must.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-12-2009, 06:22 AM   #3
thanks for that advice......I didnt think that sounded right, but seems to be a popular method on some forums.
Old 06-12-2009, 06:23 AM   #4
aaronb73's Avatar
The best advice I can give you is when you are done running the truck for the day that you leave no fuel in the tank and try to burn any remaining fuel left in the motor. Basically with an empty tank try to start the motor until it won't fire up anymore.
After that is done remove the air filter and the glow plug and add a couple of drops of after run oil in both places. Turn the motor over 2-3 seconds to spread the oil around in the motor and reinstall the glow plug and air filter. Done!
I use Sidewinder fuel and they claim that you don't need after run oil due to their proprietary mixture. If you're using a fuel with a fairly high oil content you would probably be safe just burning the remaining fuel out of the motor.
Here's a good article with some long term storage tips:
http://rc411.com/pages/howto.php?howto=52&page=1
aaronb73 is offline   Reply With Quote
Old 06-12-2009, 06:32 AM   #5
rookie042's Avatar
normally in a rustler you will run a 20% nitro blend. This is a common fuel for the .15-.20 motors Pre-manufactured fuels have a 8-12 % oil content already mixed into them. You should be able to see on the label what the stated oil content is. Hope this helps
rookie042 is offline   Reply With Quote
Old 06-12-2009, 06:42 AM   #6
So if he sold me some generic fuel that has a low oil content, I may need to add the lightening lube to the fuel? or just be double sure to use the after run oil when done for the day?
Old 06-12-2009, 08:25 AM   #7
You should not use generic fuel - there are several fuels out there and the oil content should be labled on the bottle. Oh and make sure you stay with the same fuel.
What fuel are you running?
Old 06-12-2009, 08:30 AM   #8
why should you stay with the one fuel?
Christopherp is offline   Reply With Quote
Old 06-12-2009, 08:45 AM   #9
redza's Avatar
it screws up the tuning. and the engine wont tune right?
Tebo is the man.
redza is offline   Reply With Quote
Old 06-12-2009, 08:57 AM   #10
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
The oil content should be specified... what brand of fuel is it? Note that the pro race fuels use LESS oil than the "basher" fuels... so those of us running the "good stuff" have to use more care. I've never used after-run oil except when I'm storing an engine for more than a couple of weeks.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 06-12-2009, 09:00 AM   #11
what about after 1L of 1 brand? im about to break in my 8 rtr engine and was told by hooby shop to use my 16% i have from my 1/10 and then move upto 25 after break in, as 20% is hard to get in australia. should i just go with the 25%?
Old 06-12-2009, 09:06 AM   #12
You can switch, just leave it a little rich when you do make the switch, and re-tune after the switch.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 06-12-2009, 09:10 AM   #13
I dont recall the brand right off the top of my head, but thinking about it, Im pretty sure the sales guy at the hobby shop isnt going to sell his cheapest fuel to a rookie such as myself when he can sell me a more expensive fuel without me even knowing. I will have to check it when I get home this evening. You guys have great advice...this is a very useful forum thanks to all
Old 06-12-2009, 10:37 AM   #14
so what are you guys referring to when you say "leave it rich" or what is the richness?
Old 06-12-2009, 10:40 AM   #15
Rich = excessive smoke coming out of the exhaust (there should always be some, but not a giant cloud, cloud = rich).
"Leave it rich" = once the engine is tuned, lean both needles ~1/4 turn.
LRP Z.28R - 3
Spur Gear - 0
