Old 06-10-2009, 08:59 PM   #1
PIMP_9000's Avatar
Default losi 2.0 shock mod ?
I have heard of guys doing a vent hole and using a piece of foam above the bladder. Is there an article or someone who has done this that can give me a couple of answers like drill size and vent location foam density and what not. thanks in advance
PIMP_9000 Darrin Hunt see my paint work in painting forum keyword pimp_9000
BCG Industries/Hunt Motorsports/Outlaw Garage
Losi 8ight & 8t/Kyosho ultima sc/RB engines/castle electrical items
Fearfarm rc/KBRL/The Dirt/
PIMP_9000 is offline   Reply With Quote
Old 06-10-2009, 09:13 PM   #2
pballer2777's Avatar
Trader Rating: 27 (100%+)
there was an artical inone of the recent mags but not sure which one. they said to use a #56 drill bit and to glue 2 shock orings together and put then between the bladder and cap. i was thinkin of doin this but just haven't gotten a chance.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 06-11-2009, 07:15 AM   #3
Does anyone know which mag and what month? Thanks
zzmain is offline   Reply With Quote
Old 06-11-2009, 08:56 AM   #4
Trader Rating: 24 (100%+)
zzman..
I think I got it posted on the speed shop thread..
Let me go check..
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 06-11-2009, 12:21 PM   #5
Garet Jax's Avatar
Trader Rating: 91 (100%+)
What does this mod yield?
Garet Jax is offline   Reply With Quote
Old 06-11-2009, 12:37 PM   #6
Jube's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Garet Jax View Post
What does this mod yeild?
The ability to get full rebound out of the shocks consistantly i believe.
Jubal Dike
X-Factory www.xfactoryrc.com | Tekin www.teamtekin.com | Panther Tires www.panthertires.com | DE Racing www.deracing.net | Avid www.avidrc.com | Coyote Hobbies www.coyotehobbies.com | 411 Graphics
Jube is offline   Reply With Quote
Old 06-11-2009, 01:18 PM   #7
The shocks build up easier and more consistent rebound since all you have to do is fill to the rim, drop on the bladder and tighten down the cap slowly and let the excess oil flow away no pushing up on the shock shaft. On the track I can say that the truck will not bottom on anything, the suspension seems to react quicker to bumps and turns and I never have oil build up at the top of my shocks like I used to. I cut out small stop sign shapes of proline buggy tire inserts for the cussions, I didnt like the 2 o ring idea and every thing is staying clean and holding up well. No rebuilds for 3 races with 3 qual. and 15min main plus 30min of practice each time.
crazysavage is offline   Reply With Quote
Old 06-11-2009, 01:51 PM   #8
just found the details on the speed shop thread on this forums(offroad). I tried to copy and paste but not sure whats up..lol
It's on the last page.
AaronLee is offline   Reply With Quote
Old 06-11-2009, 02:26 PM   #9
Akhor's Avatar
I thought I had posted it here but I could not find it. What I do, and this was shown to me by Adam Drake is the following:
Drill a small hole in the shock cap(on top) around the flat machined spot. This hole can be approx the same size as the hole on the side of the cap.
Take two shock o-rings and glue them together with ca glue. Glue the o-rings into the inside of the cap(center it) Fill your shocks up until about 1/16-1/8 inch from the top. Insert your bladder and make sure it is seated. Pressing lightly with your finger.
Once air bubbles escape install cap and you should have close to full rebound front and rear. What you do not want is for the shock to lock up before fully compressing, if so take a touch of oil out and repeat.
The more traction the less rebound you will run. The less traction, the more rebound. I think Adam recenly posted this as well. For the most part I always run 3/4- full rebound on all but the highest bite tracks.
Here is teh original..
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 06-11-2009, 04:42 PM   #10
malcnz's Avatar
just to clarify:
when you glue the orings in side the cap do they need to be around the drilled hole ? and does the hole need to be drilled in centre of the cap as wouldnt that be hard to do or can it be off centre? pics would be great
Thanks.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 06-11-2009, 05:04 PM   #11
Just don't block the hole with the o-rings, they need to be in the center as they support the bladder.
At the top of your shock cap you will see that milled area that allows you to get the nut driver on easily it starts out small and goes wider. Just drill the small hole half way up that.
I'll try to take some pics Friday morning for ya!
Old 06-11-2009, 06:12 PM   #12
PIMP_9000's Avatar
looking forward to it. Thanks for all the help you guys.
Old 06-12-2009, 02:05 AM   #13
So you don't have to be worried aboutr the dirt to build up in the shock bladder ? Also what would that 56 hole be in metric ? 1.3mm or 1.4mm or what ?
br
-mj
Poinas2 is offline   Reply With Quote
Old 06-12-2009, 02:29 PM   #14
BIG RE's Avatar
Trader Rating: 32 (100%+)
is anyone trying this with plastic caps? I don't want to mod $30 caps if I don't like it.
BIG RE is offline   Reply With Quote
Old 06-13-2009, 04:03 PM   #15
Jason-149's Avatar
does anybody have pictures of this mod yet? I just recieved my new 2.0 roller today and i think it already has it done. it's a very small hole on the outer edge of the shock cap?
Jason-149 is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 03:39 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 07:36 AM
Team Losi JRX-S (with many spares) 2-Bad Australia For Sale/Trade 9 06-01-2006 05:07 PM
Losi Xxx-s G+ Carpet Machine! Losi Will R/C Items: For Sale/Trade 11 12-02-2004 05:08 PM
